FixYa.com
Ultimate Sound DD1-1300S Car Audio Amplifier
All Products > Ultimate Sound > Car Amplifiers
Problems with Ultimate Sound DD1-1300S Car Audio Amplifier?
Search inside Ultimate Sound DD1-1300S Car Audio... Knowledgebase
Troubleshooting and Support
Solved Problems for Ultimate Sound DD1-1300S Car Audio Amplifier RSS Feed Post a New Problem
I have a new receiver with a preamp...
I have a new receiver with a preamp output, high volume, and I want to feed that into my power amp. Do I need to...
1 Solution
How do I drive more than two speakers with...
How do I drive more than two speakers with one stereo amplifier?
1 Solution
radace
I need repairs a burned amplifier but not that colors are those of resistance since they is burned if they could send a...
1 Solution
Problem
I am having trouble keeping my amp on when I turn up my stereo. I am running it in stereo setting on the LPF and I have...
1 Solution
american legacy II LA690 amp
i want to know if there is any way you can bypass the overhaul (green light:power, red light:overhaul) because when ever...
1 Solution
Need a power connector for a Boss IQ 3KD.1...
Where can I find a replacement power connector for a Boss IQ 3KD.1 3000W Class D Monoblock Amplifier. The screw loosened...
1 Solution
Amp isn't putting out any sound
My amp just up and quit and now it won't put out any sound. It will power on but that is as far as it gets and the LED...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Amplifier TypeMono Channel
Bass BoostWith Bass Boost
BridgableNot Bridgable
Power Output
RMS Power at 4 Ohms500 W x 1
RMS Power at 2 Ohms900 W x 1
Performance
Bass Boost Frequency45 Hz
THD at Rated RMS Power.1 %
Signal to Noise Ratio90 dB
Frequency Response20 Hz - 250 Hz
Low - Pass Frequency50 Hz - 250 Hz
Dimensions
Depth10.6 in.
Height2 in.
Width15.75 in.
Other Features
MOSFET ampYes
Input Voltage12 volt
Ultimate Sound Contact Information
Main support number1-800-567-3275
Support FAX1-866-450-5507
Email supportinfo@ultimate-sound.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
