20 Most Recent HP 49g+ Calculator Questions & Answers
Take out the batteries for a few minutes then try it again.
HP 49g+... | Answered on Aug 12, 2016
I am sorry to say that natively the HP 49G+ does not perform quadratic regressions. The models that are vailable are Linear fit, logarithmic fit, exponential fit, power fit, and best fit.
These options are available under Right SHIFT (Orange) 5 (STAT)>3:Fit data.
HP 49g+... | Answered on Feb 25, 2012
Why not use the SD card slot on the calculator? Use an SD card formatted in FAT 26 or FAT 32 of not too large capacity, say up to 2 GB. Using a computer, transfer the program on the card and store it at the root of the card: DO not store it inside a folder.
Once the program is on the card, remove the card from the computer and insert it in the SD card slot of the calculator. Turn calculator on and use the file explorer of the calculator.
Press Green Left Shift followed by the APPS key to enact the Files explorer. Navigate to the root of the SD card, copy your program and drop it in one of the three internal memories. IRAM, ERAM or FLASH
HP 49g+... | Answered on Jul 28, 2011
Welcome to FixYa!
Here's a list of things to do if your HP49G calculator does not turn on.
1. Replace the batteries. (which you have done already)
2. Press and hold "ON" then press "+" several times, then release "ON".
If chacracters still doesn't appear in the main screen, reset the calculator:
1. Press and hold "ON" then press "F3", then release both keys.
The calculator should reset. If not:
1. Insert the of a metal paper clip into the hole at the back of the calculator. Insert as far as it goes. Hold for 2 seconds then remove the clip.
2. Press "ON".
If that does not fix the problem, the calculator needs to be serviced.
Note: always use alkaline batteries.
I hope this helps.
Thank you for using FixYa!
Keep me posted.
Jas247
HP 49g+... | Answered on Mar 23, 2011
You must set FLAG 105 to Exact Mode ON.
  1. To do so turn calculator ON
  2. Press the MODE button
  3. Press F1 key to enter the FLAGS configuration settings
  4. Use Up arrow to get to the bottom of the flags list.
  5. Keep scrolling up to reach Flag 105
  6. If it does not say Exact Mode ON you should press the F3: CHK key.
HP 49g+... | Answered on Mar 02, 2011
TO GET ALWAYS DECIMAL NUMBERS PRESS MODE KEY; PRESS CAS (F3 KEY); USE THE4  SILVER BUTTONS TO GET TO THE NUMERIC OPTION--THEN PRESS F3 (the check mark).  Finally hit OK (f6) twice to get back.
HP 49g+... | Answered on Feb 26, 2011
Hi
the HP 48g+ is similar to TI83 Plus
the same problem also in the TI its an hardware failure
if you want to fix the calc let me know
ecrdn@yahoo.com
Jack
HP 49g+... | Answered on Oct 23, 2010
Press MODE to bring up the Calculator Modes screen. Press C to get to the CAS Modes Screen. On the third line, check either (or both) of "Numeric" and "Approx" (use the arrows to move to the setting and press C to check/uncheck). Press ENTER twice to save the settings.
HP 49g+... | Answered on Oct 19, 2010
If batteries are fresh use a paper clip and insert it in the hole (reset) to the left of the serial number. Press gently.
Hope it helps.
HP 49g+... | Answered on Nov 20, 2009
Turn Calculator ON Press [LeftShift][FILES]. The folder structure appears. Scroll to highlight 2:Flash . Press F3 (Format) and click OK. When finished Press F5 (cancel) and you get out of the file structure.
Hope it helps.
HP 49g+... | Answered on Sep 11, 2009
You should get a USB cable.
If you do not want to, get a Secure Digital card (formatted in FAT). Turn calculator ON, Insert card in slot.
Then [LeftShift][FILES] Open the directory where files are. Select them and use the [Copy] soft key to copy files. Got to directory where you want them copied and Copy rhem there. Exit File Manager. Remove Card and insert in SD card slot in computer, etc.
If you install the latest ROM 2.15 (hpcalc.org) the USB transfer option in IO parameters will show.
Hope it helps
HP 49g+... | Answered on Sep 10, 2009
If you do not want to lose your programs, move them to an SD Card, and perform a reset. Maybe the problem will be solved.Then you can transfer the programs to theit directory.
Hope it helps.
HP 49g+... | Answered on Sep 09, 2009
Press [MODE] button, the [F3] (CAS) Put a check mark on the field Approx. Ok OK.
Even you do not do that modification you still can have numerical result in decimal form: Put a dot at the end of an integ numer. Thus 11./3 or 11/3. or 11./3. will give you 3.66666
Hope it helps.
reset all settigns to factory defaults.also clean dust from circuit u can do it.come on.
HP 49g+... | Answered on Jan 25, 2009
just check out the connectors in the socket where you insert the battery.if they r dirty they needs cleaning.just clean them and try again.
HP 49g+... | Answered on Jan 20, 2009
HP 49g+ Calculator Logo
34 questions posted
Clive
Clive
Thomas F. Schneider
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
batteries ok not turn reset paper
  • Office Equipment & Supplies
