20 Most Recent
Mitsubishi MS-A12WA & MU-A12WA Mr. Slim Wall Air Conditioner 13 Questions & Answers
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
Mitsubishi split ac indoor light blinking unit not working
The blinking is an indicator that it needs service. Call a technician! Ask if they are experienced in mini split systems. You can check the air filters. Check the outdoor coil to see if its clean or covered up with dirt. And at the breaker or disconnect, turn off power, wait 5 mins, and turn it back on. Then give it 3-5 mins to see if it will reset itself. If this don't work, call a tech/service provider! These units are troublesome to troubleshoot.
Why does A/C display a blinking Eo code?
An EO error indicates an electronic error caused by either a control board problem or a problem with supply voltage to the heater. A single EO code is not cause for concern, but for repeated EO codes
