20 Most Recent Beko GNEV321APX Stainless Steel 526 l Fridge Freezer Side-by-Side Freezer, A Energy Rating Questions & Answers
How do I remove the front dispenser panel to replace the ice path shutter?
On the bottom edge of the panel there are two tiny slots in the plastic. Take a flat blade pocket screwdriver, insert the blade in the slot and pry it off .
1/1/2016 7:18:53 PM • Beko GNEV321APX... • Answered on Jan 01, 2016
Beko Fridge Freezer Ice Maker intermittent fault
I would agree with the the last poster just one final thing to check make sure the bottom of your fridge in the back of your fridge is dust free dust builds up on the condensers and they get blocks and they don't work as efficiently and also make sure there's the correct space between the back side top and bottom of the fridge according to the specifications I don't have them with me but you should have them in your user manual if you have one.
2/17/2024 9:54:25 AM • Beko... • Answered on Feb 17, 2024
My fridge, isn't freezing or cooling. The light is on and fan is going round. It's a frost free Beko.
Question edited for clarity and correct spelling of make and correctly Capitalised. Question moved from 'Frost Refrigerators' to Beko. Check the condenser coils are free of dust and debris. Turn off for 15 minutes by removing the wall plug. This is a power reset if your unknown, unstated model has an electronic board. Or it needs a new thermistor or a gas top up in which case you need a service call.
11/10/2023 5:26:16 AM • Beko... • Answered on Nov 10, 2023
How to remove the front control panel on Beko gnev322 to get to the ice dispenser flap. Can see two small slots, can prise them off but the panel wont budge
To remove the front control panel on a Beko GNEV322 refrigerator, you will need to follow these steps:
  1. Unplug the refrigerator from the electrical outlet.
  2. Locate the two small slots on the control panel, these are usually located on the bottom edge of the panel.
  3. Use a flat-head screwdriver to gently press in on the tabs located in the slots, this will release the panel from the refrigerator.
  4. Once the tabs are released, gently pull the control panel away from the refrigerator to remove it.
If the control panel still won't budge after following these steps, you may want to consult the user manual or contact Beko customer support for further assistance. Note: Be Careful when working with electrical appliances, especially when unplugging them.
1/28/2023 6:53:03 AM • Beko... • Answered on Jan 28, 2023
Replacement motor and fan for BEKO American style fridge freezer has 3 wires, original has 4 and different plugs . Do I just connect same colours
Question moved from Cars and Trucks. You can try, but it has 4 wires for a reason, perhaps low and high speed. Google make model condenser fan Unless it is the evaporator circulation fan? You fridge has three fans. There are many types listed here. https://www.google.com/search?q=BEKO+American+style+fridge+freezer+condenser+fan ..
8/7/2022 7:10:20 PM • Beko... • Answered on Aug 07, 2022
Beko Frost Free Fridge Freezer icing up
That is normally indicative of a failed gasket and not sealing properly. The warm moist air is sucked in and condenses to frost. You should be able to trap and grip a 2" strip of normal printing paper all the way around it.
7/22/2022 2:37:11 PM • Beko... • Answered on Jul 22, 2022
Beko Integrated Fridge Freezer | BCSD173. How to remove the protective panel on Beko fridge freezer please?
Question edited for clarity, maker name spelling. Question moved to Beko. If you go to this page https://www.ransomspares.co.uk/parts/brands/beko/fridges-freezers/bcsd173%20(7519020007)/ scroll down to Thermostat and then It shows the thermostat, the housing and the knob. It Iooks like it probably has catches that lock into those slots on the sides. Put something like a butter knife in the side to release them and pull gently.
7/7/2022 5:16:26 PM • Beko... • Answered on Jul 07, 2022
2answers
How do you remove the
If you look carefully there is a small notch like lug at the center of the drain tray which latches by itself on the tray cover. You need only a gentle action to puch this down and pull to remove the tray. Think as opening a cupboard drawer by with a small downward push before you pull.
9/4/2021 1:31:48 PM • Beko... • Answered on Sep 04, 2021
2answers
Model ap930. Temperature set at 2. Why does setting jump between 4 and 8?
Probably because the temperature control is defective
11/3/2020 1:42:44 AM • Beko... • Answered on Nov 03, 2020
2answers
Water leaking onto the kicthen floor from my frost free fridge freezer
The defrost water is not draining into the evaporation pan.
10/29/2020 1:31:01 AM • Beko... • Answered on Oct 29, 2020
I have a BEKO MODEL GN162320X the temperature display shows 0 in the freezer section and 33 in the fridge section can I reset the display
If you wish to get some details about refrigerator troubleshooting ; visit the site linked here. Pull up older posts. search with the word "Refrigerator..." http://electro-medical.blogspot.com/
7/14/2019 10:54:05 AM • Beko... • Answered on Jul 14, 2019
2answers
Beko fridge freezer I have square red sympol with an exclamation mark flashing
consult manual for trouble shooting or contact support through manufacturer website
6/29/2019 3:40:32 PM • Beko... • Answered on Jun 29, 2019
I cannot locate the defrost timer on my Beko GNEV320 American Fridge Freezer. Does anybody know please?
Replace the main control board. Spares sites show them about L79 for cost.
12/21/2018 1:32:58 PM • Beko... • Answered on Dec 21, 2018
Beko GNEV321APX Stainless Steel 526 l Fridge Freezer Side-by-Side Freezer, A Energy Rating Logo
5 questions posted
Top Beko Refrigerators Experts
Ngoro
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Beko Refrigerators
  • Beko Refrigerators
Most Popular Question
remove front dispense panel replace ice
  • Refrigerators
