20 Most Recent HP VP6111 Multimedia Projector Questions & Answers
It is a pity you did not return it after the first problem. If it is still under Warranty, I suggest you do now. Even if it is out of time, it is still 'not fit for purpose '
HP VP6111... | Answered on Mar 13, 2014
bad IC G768B on fans audio board , P#:48.J3513.A04
HP VP6111... | Answered on Apr 15, 2012
Please do not unplug the power cord before POWER is shut down or during the two-minute cooling process.
If the projector is not properly shut down, to protect the lamp, the system will detect this and cool the lamp for two minutes automatically before turning on again.
Check that you are doing this.
I suspect that this is not your problem though.
It seems that the blue light doesn't flash very long. do any other lights come on during the startup process.
HP VP6111... | Answered on Mar 26, 2011
That could be a temperature problem. Make sure the filers are clean and the fans are running.
The lamps do fail when they get hot as the gap expands and the arc will stop due to the excessive gap. It only takes a few thousandths of an inch to stop the lamp. The ballast units have a habbit of crashing also.
HP VP6111... | Answered on Mar 07, 2011
Does the bulb light up at all?? if not it may have a bad bulb,.. can easily happen anytime,.. not just when it is moved,.. check for that
HP VP6111... | Answered on Feb 09, 2010
More likely a faulty ballast. Check connections.
HP VP6111... | Answered on Jan 21, 2010
First off be sure that you plug into the input connector. As you look at the back of the projector it the VGA connector on the left. Also make sure you activate the VGA output of you computer (This mainly applies to laptops and secondary Video jacks on PCs).
HP VP6111... | Answered on Jan 15, 2010
Update HP Printer Driver in Windows 10
Make sure the printer is on and connected to the computer through your local network or USB cable.
Go to HP Customer Support - Software and Driver Downloads.
If a Let's identify your product to get started page displays, click Printer.
Type your printer model number, and then click Submit.
HP Printer Support Number USA 1 800 608 2315 Remote Help
HP Office... | Answered 4 hours ago
download & install HP Print and Scan Doctor
Steps to download & install HP Print and Scan Doctor
Download HP Print and Scan Doctor.
Run HPPSdr.exe from the download location on your computer.
Once HP Print and Scan Doctor is open, click Start, and then choose your printer.
Depending on the problem, click either Fix Printing or Fix Scanning.
is it laptop or printer. it it is a laptop and if it is windows 10 just goto display setting and give the font size with persentage.
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP-Envy-4500-Printer-Font-Size/td-p/6369207
HP Office... | Answered 8 hours ago
keep paper in its paper tray.which locate in bottom side of printer...
HP Office... | Answered 12 hours ago
HP VP6111 Multimedia Projector Logo
18 questions posted
Clive
Clive
Thomas F. Schneider
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
hp vp6111
  • Office Equipment & Supplies
