20 Most Recent
PANDIGITAL PANSCN03 Slide and Negative Scanner USB Questions & Answers
Is the Pandigital SCN02 Photolink One-Touch Scanner compatible with Windows 8?
Are you using it currentrly? What is your current Operating System? I've been searching and can't see anywhate a windows 8 driver for this scanner.
Bu let me tell you, I'm using currently a Genius ColorPage, originally released for windows 98. Installed windows 2000 driver in compatibility mode for findows XP. There is no driver for Windows XP nor for Windows 7 and coldn't make it work in Windows 7. So I run it on a computer with dual bootWindows XP / Windows 7.
When I need to scan, I simply start up as windows XP. When finished scanning, reboot to windows 7
I Have Windows 7 on a 2 Tb HD SATA and Windows XP on 200 Mb IDE. Is more economical to have a dual boot then buy a new Scanner.
If your scanner won't run on windows 8, install on another HD or a partiton, Windows 7. doual boot Windows 7 / 8 work like a dream.
See comments for this scanner in Amazon;
Amazon com Customer Reviews Pandigital SCN02 Photolink One Touch Scanner...
Just purchased pandigital scanner microSD does not fit into card reader
Just to be safe, verify that there's not any sort of obstruction in the slot. Some makers place a "dummy" card in the slot to keep it clean for shipping.
Looking at the top of your scanning unit, the mSD card should go in gold contacts facing up & towards the unit with the cut corner to the right (facing the head of the scanner). If it doesn't go with slight pressure, return to the seller.
HTH
