20 Most Recent
Nokia 5230 Nuron Protective shield Bulk Questions & Answers
Backup files Phone start-up failed
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears•Release the power button but *continue holding the home button*, for another 30 seconds.StepThanks
Hard reset nokia nuron
You may try default phone and security code to remove restrictions.ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Restriction code for Nokia 2690
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone.
Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
Nokia 2730C-1. can I unlock the network
If the phone was not used 2012, the phone number and phone have been deactivated from the network you used to pay for service. You need to set up a new contract as they expire after about 2 years of inactivity.
Backup contacts from broken nokia 2730c-1
Yes, there is a solution to backup contacts from your broken Nokia 2730c-1.
Before flashing the phone, one option is to try using Nokia Suite software on your computer to connect to the phone and backup the contacts. Another option is to remove the SIM card from the phone and insert it into a different phone to access and backup the contacts. You can also try using third-party software or services that specialize in extracting data from broken phones. It's important to act quickly to ensure you don't lose any important numbers. Good luck!
Help me Forget nokia 1680c 2 .how fo do it? please
What do you mean by a 'restriction code'? If it is your password you might have to do a 'factory reset' on your phone.
If it has been locked with the IMEI code you will need to contact your network supplier to get them to unlock the handset.
