20 Most Recent Gorenje W7543LR Red 600 mm Washer Front Loading, 7 kg, A Energy Rating Questions & Answers
Yes. A clogged filter can cause your machine to leak. Always keep filters clean-especially using well water.
Gorenje W7543LR... | Answered on Mar 09, 2015
I do not see a way to do a reset on this unit. This is the manual and shows what things you can try. Manuals Gorenje UK
Gorenje W7543LR... | Answered on Sep 30, 2014
Ub error code
Washing Machines | Answered 5 hours ago
WD-40 works great. Spray it on and rotate the dials around a few times in both directions.
Washing Machines | Answered Yesterday
a brand would really help me answer your question,most machine have a bolt down the centre of the agitator undo that to remove it,if the round disc type which is called a pulsator the is a plastic cap in the centre remove with a screw driver bolt is under that you may need a couple of screw drivers under it to pop it up
uneven load if a top loader it may need suspenion rods replacing
either a burnt out drain pump or a blown main module,test pump first if it has a burnt smell try another pump sometimes the pump can blow the board so both can end up being replaced
what model top or front loader
either blocked or faulty drain pump
Gorenje W7543LR Red 600 mm Washer Front Loading, 7 kg, A Energy Rating Logo
2 questions posted
Top Gorenje Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a Gorenje Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Gorenje Washing Machines
Most Popular Question
clogged filter cause machine leak
  • Washing Machines
