20 Most Recent Kelvinator GENUINE Refrigerator Fridge Freezer Thermal Fuse Questions & Answers
3answers
My fridge is not staying cool. compressor is running and will run for 10 hours or so then trip the breaker.
If the compressor is running and tripping the breaker, the compressor is likely overheating. This could be caused by a lack of airflow over the compressor and/or an issue with the compressor itself. You will want to check to ensure adequate airflow around the compressor and that any obstructions do not block it.
3/4/2023 10:25:37 AM • Kelvinator... • Answered on Mar 04, 2023
2answers
Lost my program manual so I can't program my kelvinator 690 514l kl690bgd friger
I can help you program your refrigerator. What kind of programming do you need assistance with?
2/26/2023 9:41:40 AM • Kelvinator... • Answered on Feb 26, 2023
Kelvinator 350 series fridge not cooling properly
possible bad temp sensor try unplugging and running if gets cold replace
12/29/2022 7:33:34 AM • Kelvinator... • Answered on Dec 29, 2022
Kelvinator f430 - freezer - how to replace pilot
Ck out here. They show a lens lamp indicator bulb. Hope this helps. https://www.repairclinic.com/Shop-For-Parts/a4b87c48/Kelvinator-Refrigerator-Lighting-Light-Bulb-Parts
12/5/2022 7:13:49 PM • Kelvinator... • Answered on Dec 05, 2022
Kelvinator Opal FN360F-L upright freezer is icing up internally at back of freezer.
This is due to a defrost timer element or heating element burn out
1/14/2022 9:25:04 PM • Kelvinator... • Answered on Jan 14, 2022
Can I please get the Kelvinator KC9650TLE Gas oven wiring diagram
Contact the Kelvinator distributor directly to inquire.
9/6/2021 5:24:31 AM • Kelvinator... • Answered on Sep 06, 2021
I need a wiring diagram for kelvinator extreme clean model kd12ww1
If the wiring diagram is not pasted somewhere inside, contact Kelvinator to request it.
4/20/2021 1:04:22 AM • Kelvinator... • Answered on Apr 20, 2021
What happens when kelvinator 4 door fridge 520l is layed down on its back when transported
it moves the oil around into lines that clog / restrict freon thru lines and oil starve compressor --can break lines and components etc usually wait a few hrs before plugging in the unit after transporting so oil can gravitate down towards compressor
5/7/2019 1:03:51 PM • Kelvinator... • Answered on May 07, 2019
2answers
MANUAL FOR KELVINATOR KM28MGB GRILL
I have a Kelvinator Microwave oven and grill Model KM28ECS2 but the microwave won't heat. What could the problem be??
3/31/2019 7:53:55 PM • Kelvinator... • Answered on Mar 31, 2019
I have a kelvinator impression series twin air no frost 500. getting a leak from inside the fridge with water coming out where the light is in that area. I have removed the globe replace the seals
There is probably a drain tube that is plugged as the water should flow down to the tray under the fridge.
3/4/2019 11:04:00 PM • Kelvinator... • Answered on Mar 04, 2019
Kelvinator GENUINE Refrigerator Fridge Freezer Thermal Fuse Logo
1 questions posted
Top Kelvinator Refrigerators Experts
vince
john h
Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kelvinator Refrigerators
Most Popular Question
kelvinator 430l fridge old school
  • Refrigerators
