20 Most Recent Canon PIXMA MG3250 All-in-One Inkjet Printer 9.2 ipm, 4800x1200 DPI, Colour, Wi-Fi, PC/Mac Questions & Answers
Why? What is the problem? You will not find a maintenance manual for this unit, so if you are just looking to strip it for parts use an appropriate screwdriver and pliers.
Canon PIXMA... | Answered on Oct 19, 2018
If you wish to get some details; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
Canon PIXMA... | Answered on May 02, 2016
http://www.canon.co.uk/support/consumer_products/products/fax__multifunctionals/inkjet/pixma_mg_series/pixma_mg3250.aspx?type=drivers&language=&os=WINDOWS%20XP%20%2832-bit%29 Download your drivers from above link.
Canon PIXMA... | Answered on Mar 13, 2016
A wifi printer needs to connect to your wifi network and it needs to be recognized by Windows.If your wifi network is already set up and working with other devices (tablets, smartphones, etc) , then you may be dealing with a simple security issue ( you may need to enter the proper passphrase, network key, etc.when you set up the printer) . If you do not have a wireless network already set up, then things get very complicated!!!
yes, you can, have go to this site and download the manual, all is explained step by step.:
https://www.canon.co.uk/printers/inkjet/pixma/pixma_mg3250/
select first brochure - all explained in short and then go to downloads and download full manual.
hope this will help you - do not forget to vote...
Canon PIXMA... | Answered on Mar 24, 2015
Not sure if MG3250 has 2 sided printing option, but if it does, there is a tick box with 'Duplex printing' next to it in 'Printer properties' on 'Quick setup' page. Tick the box!
Canon PIXMA... | Answered on Mar 02, 2015
The C amber light means the colour cartridge is empty. You can still send documents and files to printer, but it may say that the cartridges are now empty. You can bypass this message by holding down the stop/reset button on the printer for around 5 seconds.
This YouTube video will help. Canon MP230 Override Empty Cartridge Message
Canon PIXMA... | Answered on Feb 26, 2015
And once you had removed the paper jam, did the printer respond properly?
Canon PIXMA... | Answered on Feb 05, 2015
Hi
Please find below a fairly comprehensive guide to using envelopes on your machine
The address is automatically rotated and printed according to the envelope's direction by specifying with the printer driver properly.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif You can only print on envelopes with the computer.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Do not use the following envelopes. They could jam in the machine or cause the machine to malfunction.
- Envelopes with an embossed or treated surface
- Envelopes with a double flap
- Envelopes whose gummed flaps are already moistened and adhesive Prepare envelopes.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Press down on all four corners and edges of the envelopes to flatten them.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the envelopes are curled, hold the opposite corners and gently twist them in the opposite direction.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the corner of the envelope flap is folded, flatten it.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Use a pen to press the leading edge in the inserting direction flat and sharpen the crease.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif The envelopes may jam in the machine if they are not flat or the edges are not aligned. Make sure that no curl or puff exceeds 0.1 inches (3 mm). Load envelopes.
(1) Open the front cover gently, and extend the paper support.
(2) Use the right paper guide (A) to slide both paper guides all the way out.
(3) Load the envelopes in the center of the front tray WITH THE ADDRESS SIDE FACING DOWN.
The folded flap of the envelope will be faced up on the left side.
Push the envelopes all the way to the back of the front tray.
Up to 5 envelopes can be loaded at once.
(4) Slide the right paper guide (A) to align the paper guides with both sides of the envelopes.
Do not slide the paper guides too hard against the envelopes. The envelopes may not be fed properly.
Do not overload envelopes by stacking until the top of the stack touches the paper guides. (5) Open the output tray extension.
Open the paper output tray.and extend the paper output support.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Be sure to open the paper output tray when printing. If not open, the machine cannot start printing. After loading envelopes
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image003.gif Select the size and type of the loaded envelopes on the print settings screen of the printer driver. You may find it easier to download the manual from here
Canon PIXMA MG3250
and install it on your desktop for future reference
Cheers
Canon PIXMA... | Answered on Nov 13, 2014
This could be a number of things, but most likely a part has failed & unfortunately not something that can be diagnosed without seeing the device.
Canon PIXMA... | Answered on Aug 24, 2014
You can download and execute a program that will install the User Manual, and put a shortcut on your desktop here... http://www.canon-europe.com/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MG_series/PIXMA_MG3250.aspx?type=manuals&manualid=tcm:13-957954
Canon PIXMA... | Answered on Jul 07, 2014
Hi. If you do the procedure correctly. That means that main board is defective
Canon PIXMA... | Answered on Jul 10, 2019
If your printer is connected wirelessly to the network just install the canon printer app in your tablet
Canon PIXMA... | Answered on Jun 30, 2019
please help me....
I m trying to scan my document but it is showing error code 2,140,2 on PC and error code E5 at printer....my catridiges is empty is it because of that reason............
Canon PIXMA... | Answered on Jun 26, 2019
Dear kindly reset the printer to its factory default setting.
Canon PIXMA... | Answered on Jun 13, 2019
Try to remove the print head and turn on the the printer without it, sometimes print head cause a shortcut or power supply is defective
Canon PIXMA... | Answered on Jun 12, 2019
Canon PIXMA MG3250 All-in-One Inkjet Printer 9.2 ipm, 4800x1200 DPI, Colour, Wi-Fi, PC/Mac Logo
22 questions posted
Clive
Clive
old marine
old marine
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
new modem now cannot use printer as its
  • Office Equipment & Supplies
