HelloThere are two possibilities for this fault. The first one is of its loading belt. If loading belt, that fastened to loading gear wheel to loading motor get loose or broken, the tray won't come out or go inside. Just place your ear very near to the player, and push eject button and listen, whether there is a motor running sound for at least 3 seconds. If you hear this sound, make sure that the belt is brokenn. The second chance is with loading motor itself. If it do not get proper voltage or got dmaged, the fault you describe here will occur. To replace this motor, you have to disassemble the CD mechanism. You must have all the tools to do the work and experience to disassemble and reassemble the CD mechanism. The motor is not a costly part, and can be bought from most of the electronic spare part selling shops at your town. OK.
You can change the Region Code of you DVD player but be aware that you have a limited number of changes, then the DVD player will be stuck to a certain region.
Search in the Options menu and change the region code to one printed on the french dvd case. To watch DVDs from your region again you have to change the region once more. Watch for changes left.
Hi, you might have to turn the CC feature off from your TV and select the CC feature from the DVD disc set up.Refer to page 35 of the owners manual to get the correct language caption on your disc(dvd): basically press the audio key on your remote control until the desired captioning appears.
For this unit the component output (green, blue, and red cables) only work for the DVD player portion of it. You will need to connect either the av input on the back or the front with composite (yellow, red, and white cables) to your television in addition to the component cables I assume you have connected already. Once you have done so you will need to switch this unit over to the right av output in order to access the vcr and also switch your television over to the right av input in order to pick up the signal from the vcr.
This is a DVD player. It will not write to DVD but will play discs you have recorded elsewhere. You could (with non-copy protected discs) dub the DVD to VHS. To go the other way, you would need to connect the player to a computer with appropriate software or other DVD recording device.
well it sounds like a problem with your lense. so just take it apart and look at your lens and see if there is anything wrong or out of the ordinary with it.
You may have to push the channel buttons on the source and check the video unit until you see whats playing on the main unit once you have a picture comming thru you should be able to record. if not let me know we can figure out some other solutions to get you up and recording.
This is a known issue with this TV. The following might resolve it:
Check Mute and Volume:
Ensure that the TV is not muted and that the volume is set appropriately. Sometimes accidental button presses can lead to muted sound or low volume.
Inspect External Speakers:
If you're using external speakers, verify their connections. Loose cables or faulty speakers can cause sound issues.
Test Different Inputs:
Connect a non-HDMI device (such as a DVD player) to the TV. Observe if the sound distortion occurs. If it doesn't, the problem might be related to the HDMI signal from your Virgin box.
HDMI Troubleshooting:
If the issue persists with the DVD player over HDMI, consider the following:
HDMI Cable: Check the HDMI cable for damage or loose connections.
Virgin Signal: Contact Virgin to inspect the signal/lines and replace the box if necessary.
Mainboard Replacement (if needed):
If the sound distortion persists, it could be due to a faulty sound processor chip on the TV's mainboard. In this case, consider replacing the mainboard.
TOSHIBA 42RV500E, 42RV500T, 42RV500Y, 46RV500E, 46RV500T User Guide (manualmachine.com)
There may be loose contact or track open in main board.So try to check the main board thoroughly where you may find the loose of connection or track open.
Locate the Battery Cover: Look for the battery cover on the back of the remote control. It is usually a small compartment that can be easily opened.
Remove the Battery Cover: Depending on the design, there may be a latch, screw, or sliding mechanism to secure the battery cover. Use your fingers or a small screwdriver to open the compartment.
Remove Old Batteries: Take out the old batteries from the battery compartment. Pay attention to the orientation of the batteries, so you know how to insert the new ones correctly.
Check Battery Polarity: Take note of the positive (+) and negative (-) signs inside the battery compartment. Make sure to insert the new batteries with the correct polarity to match these markings.
Insert New Batteries: Place the new batteries into the battery compartment, ensuring they are properly aligned with the correct polarity. Press them down gently to make sure they are secure.
Replace Battery Cover: After inserting the new batteries, close the battery compartment cover securely. If it has a latch or screw, make sure it is fastened properly.
Test the Remote: Point the remote at the device it controls (such as a Toshiba TV) and test whether it responds to your commands. If the remote is working correctly, you have successfully replaced the batteries.
Dispose of Old Batteries: If the old batteries are no longer usable, make sure to dispose of them properly. Many communities have designated recycling locations for batteries.
Serial numbers don't work Judy
https://www.google.com/search?q=A10A13799C3300
They are purely a numerical identifier of when it was made, year, day, number on the shift, whether it Joe or Billy who did final inspection.
With a MODEL number I can find them easily with just 'make model manual'.
Toshiba
http://www.toshiba.com > support > content
PDF
Thank you for purchasing this Toshiba LCD TV. This manual will help you use the many exciting features of your new LCD TV. Before operating your LCD TV, please.
62 pages
Toshiba
PDF
Thank you for purchasing this Toshiba LCD TV. This manual will help you use the many exciting features of your new LCD TV. Before operating your LCD TV, please ...
62 pages
No you can't the Insignia remote is for that model television only. Companies don't make their remotes so they operate other makes of televisions. Buy a Copy Remote for the Toshiba
https://www.google.com/search?q=insignia+remote+NS-RC03A-13
