my toshiba dvd player just stoped working, we havent moved ti or touched besides basic function, it...
(More)
my toshiba dvd player just stoped working, we havent moved ti or touched besides basic function, it wont read any disc's such as dvd's or cd's. i think it might need the eye cleaned but before i do anything i wanted to ask somone.
The sound on my Toshiba SD-4700N DVD player goes in and out. The optical connection port is...
(More)
The sound on my Toshiba SD-4700N DVD player goes in and out. The optical connection port is defective. When you touch the cable or position it correctly the sound will work but is still unreliable. I have replaced the cable in order to see if it was a bad cable. It is not a cable issue. Can I replace this small black optical piece on the circuit board?
My SD-4700 periodically does not load. Well the tray closes and the LCD screen flashes...
(More)
My SD-4700 periodically does not load. Well the tray closes and the LCD screen flashes "LOADING" then I get "DISC ERROR". When it is "LOADING" the inside of the machine makes what sounds like scratching sounds. I took off the top and watched inside while it is trying to load the mech assembly does lift the disc but motor struggles to spin the disc. I can get it to spin when I move the top of the assembly where the spin motor lifts too. So, does this mean I have a bad mechanism assembly and I need to replace the whole thing?
I have problem with Toshiba SD-K760SU on the television LG scarlet, and launch "no se?al"...
(More)
I have problem with Toshiba SD-K760SU on the television LG scarlet, and launch "no se?al" but audio is ok, the conection is for componet out, wath to do
I have a toshiba dvd player model no. SD-K760SU and it will not load any of my dvds. I put them in...
(More)
I have a toshiba dvd player model no. SD-K760SU and it will not load any of my dvds. I put them in the tray and then the player says "no." I am ok with opening the player up so how can i fix this?
This seemed to show the same symptoms as the one that suggested the ribbon cable problem. ...
(More)
This seemed to show the same symptoms as the one that suggested the ribbon cable problem. Insert and "Load" Then "No" on the readout. I reinserted the ribbon cable and then tried to load the Disc. It seemed to exhibit the same malfunction and code. But as before it seemed to try to spin up and not succeed. I gave the top spindle a little nudge and it spun up and started playing. What needs replacing here? The spindle motor unit? Or a single small component somewhere? And what is the number of the unit in order to get it. martindsloan@yahoo.com
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
