20 Most Recent Toshiba SDK615 Multi-disc DVD Player Questions & Answers
Maybe its time for a new player or maybe the the sensor needs cleaning
Toshiba SDK615... | Answered on Aug 08, 2009
I had a similar issue and now mine is opening closing opening and then powering off?
Toshiba SDK615... | Answered on Apr 23, 2008
Not certain about this, try tapping MENU on your remote control, select SETTINGS then LANGUAGE.
Toshiba... | Answered 3 days ago
I plug headet in the service use only of my TV toshiba model 24HV1OE and something went wrong .what should I do to fix it?
Toshiba... | Answered on May 18, 2019
Hi Daren, it's a very strange fault, the one you mention
I sent you a link that talks about a similar failure on a Toshiba TV
I hope it will help you and you can solve the problem
But I suggest you look for a specialized technical service
Greetings Franco Dosil
Hola Daren, es una falla muy extra?a, la que comentas
Te envio un link que habla de una falla parecida en un televisor Toshiba
Espero te sirva y puedas resolver el problema
Sino te sugiero busques un servico tecnico especializado
Saludos Franco Dosil
Toshiba... | Answered on May 16, 2019
If the current firmware in your blu-ray player supports multi region then try this.
1. Power on the blu-ray player.
2. Press "Setup" on the remote to enter Setup Menu.
3. Using the remote, enter "8520". A new submenu will appear.
4. Set DVD region code to "0" for DVD Multi Region.
5. Set BD region code as required using the remote buttons.
"1" = Region A, "2" = Region B, "4" = Region C
6. Press "Setup" button to exit the menu.
If this does not work then try upgrading the bluray firmware.
Search for Toshiba BDX2150 firmware and see if there is a newer firmware than the one you have installed.
Toshiba... | Answered on May 14, 2019
hi Cheryl.
Press the "MENU" button, select Prefer, highlight Parental Control and press the right arrow key or menu button to enter the PIN code entry screen. 0000 is the default password. When the correct PIN # is entered the Parental Control Menu opens and you can change your settings and PIN code here.
Changing the TV password
or read up some more at this manual.
Toshiba 19L4200U User Manual Forgotten Pin Code Changing Or Deleting Your...
or this one.
4 digit pin code for toshiba tv Google Search
Toshiba... | Answered on May 12, 2019
Hi Roy, I can not find the service manual for this TV,
Is it an overhead TV? if so, it would seem that it is out of alignment of the LCD cells
Try disconnecting all the TV's devices and see if the same happens when you put the menu?
It does not seem, a problem of interference, so it is observed in the photo
I await your comment
Hola Roy ,no encuentro el manual de servicio de este televisor,
Es un TV retroproyector? si es as?, parecer?a que esta fuera de alineaci?n de las celdas LCD
Probo desconectar, todos los aparatos del televisor y ver si ocurre lo mismo cuando pone el men??
No parece, un problema de interferencia, por lo se observa en la foto
Espero su comentario
Toshiba... | Answered on May 11, 2019
Could be open internal fuse or power supply failure
Toshiba... | Answered on May 08, 2019
The code will be found in the remote control if it is programmable and compatible.
Toshiba... | Answered on May 04, 2019
Toshiba SDK615 Multi-disc DVD Player Logo
Popular Tags
5 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
even when dvd in tray correctly says
  • Televison & Video
