I moved the player last night and accidently tipped it and dislodged the dvds inside.  When...
(More)
I moved the player last night and accidently tipped it and dislodged the dvds inside. When I plugged it back in, it wouldn't open or play. I used a screwdriver to open the top and I put the discs back into place, but it still won't open, won't play. Is there anything else I can try?? Thanks, LInda D
Dvd player Toshiba SD-2705 will either shut off during a movie or it will shut off and start the dvd...
(More)
Dvd player Toshiba SD-2705 will either shut off during a movie or it will shut off and start the dvd over just to shut off again. When I turn the power back on, it will work for about 5-10 minutes then will shut off again. I checked all the power connections and they are fine. Has anyone had this problem? Please help. I really like my Toshiba multi disc player.
For some reason the dvd player will not closed properly nor will it play any of my movies. What can...
(More)
For some reason the dvd player will not closed properly nor will it play any of my movies. What can I do to fix the problem
DVD player worked great until my son pulled on carousel, now it seems off track and will not...
(More)
DVD player worked great until my son pulled on carousel, now it seems off track and will not recognize any discs, the carousel will just keep opening and closing.
I have a Toshiba SD-2705 DVD player that has worked flawlessly for several years. Until now, I have...
(More)
I have a Toshiba SD-2705 DVD player that has worked flawlessly for several years. Until now, I have used the analog RCA jacks for the sound without any issues. I just purchased a new A/V receiver that has jacks for digital sound (both optical and coax). I want to upgrade to the better digital surround sound, so I have connected my HDTV tuner and CD player to the A/V receiver using a TOSLink optical cable and get sound from them perfectly. However, when I connected the DVD player this way (I have tried both optical and coax), I get no sound at all. I have connected the DVD player using the same TOSLink cable as the HDTV tuner, so I know the cable is OK. I even connected the DVD player into the HDTV input port on the receiver, to see if there is a problem with the DVD input port, but still no sound. I have set the DVD player to use PCM/Stream with 48Khz sampling in the Setup menu as per the user manual. Do you have any advice for what I can check next? I can continue using the analog RCA cables, but I would REALLY like to watch my movies in DTS surround sound! Thanks for any help!
I have a Toshiba SD-2705 5 disc DVD/CD player. I can play DVD's fine, but now when I try to play...
(More)
I have a Toshiba SD-2705 5 disc DVD/CD player. I can play DVD's fine, but now when I try to play any kind of CD, even clean manufactured CD's they play at a quicker speed and skip every ten seconds or quicker, it sounds like a skipping 33 record playing at 78 rpm. The Toshiba web site doesn't even list this player anymore. I'm lost.
Help, Please !!
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
