My Toshiba SD-V290 can record however, I cann't see recorded data. I can see however any DVD and...
(More)
My Toshiba SD-V290 can record however, I cann't see recorded data. I can see however any DVD and previously recorded VHS.
Any tape won't play, I just get an "Atr" message. The counter doesn't even run. Thanks for...
(More)
Any tape won't play, I just get an "Atr" message. The counter doesn't even run. Thanks for your help!
Toshiba SD-V290. The door won't open. I've tried other posted solutions and they didn't work. There...
(More)
Toshiba SD-V290. The door won't open. I've tried other posted solutions and they didn't work. There is a DVD in it. What can I do to open the door and eject the DVD? Thanks
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
