My toshiba dvd player works for 20 min then breaks up and stops. If I try again after several hrs...
(More)
My toshiba dvd player works for 20 min then breaks up and stops. If I try again after several hrs the dvd plays the previously problem section OK but for only another 20 min.
The machine is completely dead like it isn't getting electricity; however the tv is hooked into the...
(More)
The machine is completely dead like it isn't getting electricity; however the tv is hooked into the same power strip and it is fine so something must be wrong with the dvd/vcr player. Any ideas?
my laptop reads cd and burns cd's but when i place a dvd into it and try to read or burn it says...
(More)
my laptop reads cd and burns cd's but when i place a dvd into it and try to read or burn it says "place a disk" and opens the tray as if none was loaded.. my pc originally came with a pioneer dvd-rw dvr-k17lf 2.52 i have a toshiba satellite a205 s4629.. it did work before but have no idea why it stopped working.. if anyone can help id appreciate it thanks in advance..
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
