I can not get my remote off of DR 2.. I have tried hitting setup and 1. I have had this problem...
(More)
I can not get my remote off of DR 2.. I have tried hitting setup and 1. I have had this problem severl times and always forget how to fix it.. Please help!
When I turn on the machine (worked fine before) I get an error message...ER7071. I contacted Toshiba...
(More)
When I turn on the machine (worked fine before) I get an error message...ER7071. I contacted Toshiba and they were NO help at all. Can you help??
I have recorded material and played it back. Everything was fine. Weeks later I went to view it...
(More)
I have recorded material and played it back. Everything was fine. Weeks later I went to view it again and I got "Blank Disc Loaded" or "Can't Play Disc". I cleaned the disc and the player. Now more and more of my discs are having the same problem. I have a Toshiba D-R4SU.
Remote control for Dr-2 will nor work. Replaced batteries then bought a new remote which does not...
(More)
Remote control for Dr-2 will nor work. Replaced batteries then bought a new remote which does not work either.
I picked up a new condition Toshiba D-R2 DVD recorder and all was well until a day ago when the tray...
(More)
I picked up a new condition Toshiba D-R2 DVD recorder and all was well until a day ago when the tray would not open. When I shut the recorder off,just before it powers down, it says "open"... but nothing happens. Is there a way to re-set the machine? Is there a backup way to open the tray? There isn't a disc inside.
Thanks.
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
