Honeywell HZ335 Ceramic Compact Heater
Problems with Honeywell HZ335 Ceramic Compact Heater?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Troubleshooting and Support
Solved Problems for Honeywell HZ335 Ceramic Compact Heater RSS Feed
View More Results for Honeywell HZ335 Ceramic Compact Heater
Questions and Unsolved Support Problems
Unsolved Problems for Honeywell HZ335 Ceramic Compact Heater RSS Feed
Answer
There is a piece of gum that is behind the screen face on the front of the unit. I would like to be... (More)
Answer
I went into mode and set a temperature when I see the flashing thermometer but the heat keeps... (More)
Find a Manual
Honeywell HZ335 Ceramic Compact Heater Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Honeywell HZ335 Ceramic Compact Heater
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Expansion Water Tank Boiler Expansion Tank
When water is heated the water will increase in volume. The thermal expansion tank in a boiler heating system is there to allow the extra volume of... written by heatman101
Valve Pressure Reducing or Pressure Reducing Valve
The pressure reducing valve on a boiler is the way that the water pressure in the boiler is controlled. The standard pressure for many hot water... written by heatman101
How a furnace operates and what you can do to troubleshoot.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the... written by Therinnaiguy
Trouble shooting your gas Furnace
If you are having trouble with you gas furnace they are really not that complicated to figure out. Most of the newer gas furnaces within the last 10+... written by moyerboy2
heater controls
I hear about alot of problems that people have with heaters. Some may be electric and some gas. I am going to give up a few ideas that were given to... written by tdulany
how to fix your gas furnice
most gas furneses have a red light on circuit board wich is located on intake. turn heater off then have someone turn it back on while you watch the... written by kellys4640
Cruise Control for Your Oil Burner to Save Money
The Beckett HeatManger is a microprocessor controlled device that will manage the on/off cycles of your boiler. Every time your boiler has to shut... written by heatman101
Cleaning of flame sensors
In my experience I have seen many people use sand paper to clean the flame sensors on furnaces. It is best to use a small stainless steel brush to... written by Robotinner
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Honeywell HZ335 Ceramic Compact Heater
Nationwide | 8884489872 | Website
Nationwide plumbers where ever you need us any tim... Read More
Featured Listing
Nationwide | 8009059506 | Website
Traditional water heaters use a storage tank to hol... Read More
Featured Listing
Nationwide | 866 3278928
Ratings for the
Find a Warranty
Specifications for Honeywell HZ335 Ceramic Compact Heater
Key Features
Type
Compact
Features
Power Indicator, Oscillating, Timer
Power Source
Electric
Heating Element
Ceramic
Heating Levels
2 Levels
Power
Power
1,500 Watt
Warranty
Warranty
5 Years
Honeywell Contact Information
Main support number800-328-5111
Describe your problem:
Top Heater Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
