20 Most Recent Nikon Coolpix L320 Black Digital Camera 16.1 MP, 26x Opt, SD Card Slot Questions & Answers
Possible Solutions.
1. Charge the battery
2. If still not turning on, try using a little alcohol and wiping the battery terminal(s) on the battery and the battery terminals in the camera. Use a QTip and allow to completely dry before recharging the battery or inserting it into the camera.
2. Replace the battery with new one.
3. On/Off switch may be defective on camera. Charger may be defective. Wire connecting power from charger to wall socket may be improperly connected or loose.
Nikon Coolpix... | Answered on Sep 02, 2016
This happens due to over extension of lens by motor or encoder failure. Please try few things.
1. Remove battery wait for 20mts, replace with fully charged battery, lens may return to original position.
2. Struck up click button also give similar problem.
Nikon Coolpix... | Answered on Apr 28, 2016
after changing the battery and gently push back on the lens it should automatically close if not then check around it it must be something stuck in between it
Nikon Coolpix... | Answered on Aug 24, 2015
Is it the screen, or the screen protector ? If the latter, just remove it and replace it. If it is the actual screen, first of all try a lint-free cloth barely dampened with distilled water, and test it on a corner, see if that works. On no account get the camera wet. If that is unsuccessful, try adding a very little diluted washing-up liquid, and try again. Should that not succeed, I would advise taking the camera to your local repair facility for their expert advice.
Nikon COOLPIX... | Answered on Aug 24, 2019
Not sure exactly what the issue is here - could you be more specific please ? Thank you.
Nikon COOLPIX... | Answered on Feb 20, 2019
I would suggest you go to the Nikon support site and see if there is a version you can download from there.
Hi
Here are some suggestions to try and see where the problem may be:
1. Have you tried to charge the battery? We would suggest trying different USB sources (e.g. a USB port on a computer as well as the Nikon supplied AC adapter)
2. Could the battery be dead? If you have tried to charge the battery in the camera via USB then there is a chance the battery is dead and needs replacing. If the camera had not been used for a long time and the battery was stored with little or no charge, the battery may now be un-chargeable.
3. If the camera has been left unused for a long time the internal battery that keeps the time/date may have discharged. You need to be able to set the time/date before the battery can be charged. If you plug the camera into a USB power source and you can see the menu on the LCD then set the date/time.
We hope these suggestions help to get the camera back up and running
Nikon COOLPIX... | Answered on Jan 24, 2019
You have two main choices. Yes, you could buy a new memory card. But I find the extra small cards can be easily lost or misplaced.
A better method is to transfer the images from the camera to a computer or laptop. It is also possible to transfer the photos through the computer or laptop onto an external hard drive with a much larger memory as a back up. Then you can re-use the card you already have.
Nikon COOLPIX... | Answered on Jan 12, 2019
Nikon Coolpix L320 Black Digital Camera 16.1 MP, 26x Opt, SD Card Slot Logo
8 questions posted
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
nikon coolpix l320 wont turn
  • Cameras
