20 Most Recent
Toshiba TP55H95 55" Rear Projection Television Questions & Answers
I Have a major convergence
Color arching.... Ahhh Yeah they eventually do that after a few years. Good news is all you need is a screw driver and some of your time and patience.
The color gun is a small box with 3 screws on it. (Blue, Red and Green. Turning the screws (Slightly) on the gun will get rid of the color arching. I had blue arching on a sony 65" Rear projection a year later it was red arching if you leave it long enough it will be arching and in and out flashing of solid color. Whole mind trip you don't want to venture on.......
The box on my sony was in the very front of the tv. I removed the front speaker panels and accessed it very easily. The hardest part is getting the front panel off. Yours may be in the back.
Best regards and Semper Fi...
How do u install t.v?
when you bought a tv the store will teach you how to ins tall tv or the provider will install your brand new tv in your home
Convergence
About 35.00 - 70.00 to do it yourself depending on parts.
Turn of sometime
I would check out your power supply and shut down circuitry as thats what yourset is doing when it shuts down its ging into the protection shut down. You can get the power supply and shutdown troubleshooting quide for your set at the following link for 10.99 and if you request that they email it they will. You just have to return after you order and click on the contact link to request they email instead of mail your manual. Heres the link.
http://servicemanuals.vstore.ca/
Toshiba TP55H95 Shutting Off
the power supply board may not be the problem as that only provides the voltages that go to the other areas of the chassis. Where as a manual will explain where the voltages go and what has to happen for the set to start. the power supply could be good but a leaky diode on say the signal board could allow voltages to increase thereby shutting the set down. Unless youre really good at troubleshooting, I would highly recomend getting a manual.
Red light bflashing
Sometimes a power surge will cause a projection back TV to shut down and flash like that. If you unplug it from the wall and let it sit for a minute and then plug it back in, it should reset itself. If that doesn't work it will probably have to be serviced. If it does work, make sure you get a nice surge protector so you don't fry your TV.
Change batteries on my toshiba se-r0001 remote
- Locate the Battery Cover: Look for the battery cover on the back of the remote control. It is usually a small compartment that can be easily opened.
- Remove the Battery Cover: Depending on the design, there may be a latch, screw, or sliding mechanism to secure the battery cover. Use your fingers or a small screwdriver to open the compartment.
- Remove Old Batteries: Take out the old batteries from the battery compartment. Pay attention to the orientation of the batteries, so you know how to insert the new ones correctly.
- Check Battery Polarity: Take note of the positive (+) and negative (-) signs inside the battery compartment. Make sure to insert the new batteries with the correct polarity to match these markings.
- Insert New Batteries: Place the new batteries into the battery compartment, ensuring they are properly aligned with the correct polarity. Press them down gently to make sure they are secure.
- Replace Battery Cover: After inserting the new batteries, close the battery compartment cover securely. If it has a latch or screw, make sure it is fastened properly.
- Test the Remote: Point the remote at the device it controls (such as a Toshiba TV) and test whether it responds to your commands. If the remote is working correctly, you have successfully replaced the batteries.
- Dispose of Old Batteries: If the old batteries are no longer usable, make sure to dispose of them properly. Many communities have designated recycling locations for batteries.
3/9/2024 3:29:56 AM •
Toshiba...
Answered
on Mar 09, 2024
