20 Most Recent Toshiba TP50H50 50" Rear Projection Television Questions & Answers
Likely has bad convergence chips and one or more open fuses on SMPS board.
Toshiba TP50H50... | Answered on May 08, 2014
The flashing power light on those Toshibas is usually caused by capacitors on the power board having failed solder connections. I have fixed them before by removing the power board and resoldering the capacitors. If you have experience with soldering and electronics it is an easy repair. Most shops will recommend replacing the entire board since their labor to repair it would probably cost more. Toshiba put out a service bulletin on this issue which a good technician should be aware of. (If memory serves the capacitors are C109 and C110.  Since your TV still turns on you probably haven't blown fuse F860 which often blows when these capacitors act up.)
If you would like further help with this please post a comment back here.
Toshiba TP50H50... | Answered on Apr 09, 2014
try shopjimmy.com or encompass.com
Toshiba TP50H50... | Answered on Feb 15, 2014
you can remove the screen but there is a easier way, from rear with cover removed use a swiffer cleaner to get at the webs etc. Gently.
Toshiba TP50H50... | Answered on Dec 22, 2012
The Toshiba part number is: 23837513, but htis part is listed as no longer available. All you can do at this point is to try and call different Toshiba parts distributors or service shops to see if anyone still has one around.
Dan
Toshiba TP50H50... | Answered on May 10, 2012
If toshiba projection go to main menu and engage convergence to look--should offer some points on screen where you can try to adjust.
If badly skewed or will not adjust (based on model number posted here) both the stk-392-110 chips will have to be replaced and the set adjusted.
This can be a do it yourself repair if you have some skill--soldering is involved as both chips have 18 pins each.
Let me know what you find and if you have questions.
Toshiba TP50H50... | Answered on Mar 22, 2012
sir try to check this link http://www.interliquidparts.com/ good day and best regards.
Toshiba TP50H50... | Answered on Aug 20, 2011
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Toshiba TP50H50... | Answered on Aug 06, 2011
Set should be worth fixing ,The most common cause of this is Bad STK ICs . They are Big Black ICs and will have the part number on them,example STK392-110
Toshiba TP50H50... | Answered on Jun 29, 2011
Repair or replace the power supply
Toshiba TP50H50... | Answered on Jun 14, 2011
It's the problem of overheating in the power supply board of the TV.on the power supply board of the tv there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
This will help.
srobinsota,
Available at http://www.encompass.com. I have a tip at http://www.fixya.com/support/r6210638-replace_broken_projection_tv_screen which should help with the removal and replacement procedure.
Thanks for using FixYa and for the great rating. Please consider a testimonial.
hardrocko
Toshiba TP50H50... | Answered on Jan 08, 2011
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem....
Toshiba TP50H50... | Answered on Jan 01, 2011
The blinking LED is the Fault code for your set. Its shutting itself down into protection mode to stop from further damaging itself. Kinda like a fail safety. My fix instruction differ for rear projection than that of PDP or LCD but its the same. Just a dif set up inside the set.
Toshiba TP50H50... | Answered on Aug 06, 2010
hi
blakedidit,
Thanks in advance for choosing Fixya for assistance!
I would like to have a clarification request before I present my solutions
to your problem.
does the fuse comes from a circuit like these?
As I look for more possible solution to your problem, would it be
possible to to post part number of the component within the board
or send an image where I can encircle the possible causes.
I need also to know if, it the TV do still have a sound even without
the fuse? or a raster perhaps , or is the Flyback, oscillating?
Regards,
palaboy
Toshiba TP50H50... | Answered on Jul 18, 2010
Toshiba TP50H50 50" Rear Projection Television Logo
Popular Tags
67 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
toshiba tp50h15 shuts off
  • Televison & Video
