Toshiba 55HX70 55 in. Rear Projection Television
Problems with Toshiba 55HX70 55 in. Rear Projection Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Toshiba 55HX70 55 in. Rear Projection...
Troubleshooting and Support
Solved Problems for Toshiba 55HX70 55 in. Rear Projection Television RSS Feed
View More Results for Toshiba 55HX70 55 in. Rear Projection Television
Questions and Unsolved Support Problems
Unsolved Problems for Toshiba 55HX70 55 in. Rear Projection Television RSS Feed
Answer
Picture began flickering around the edges for a couple days, then when I turned the set off the on... (More)
Answer
55' toshiba tv turns off and power button blinks , comes on only when I can get the blinking to stop
Answer
power is live and makes the usual ping when switched on but no picture or sound?
Answer
my toshiba rear projection TV model #55HX70 (mfg date may 2001) works for about half an hour then... (More)
Answer
My TV will not come on, when I press the on button it gives me a short series of litle clicks and... (More)
Answer
While watching Cable TV the screen has some small vertical lines that are only like 1/2 inch long... (More)
Answer
I have a Toshiba Cinema Series HD model 55HX70 chasis no. TAC 0066 the colors are off, picture rolls... (More)
Find a Manual
Toshiba 55HX70 55 in. Rear Projection Television Manuals & Guides
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Toshiba 55HX70 55 in. Rear Projection Television
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Toshiba 55HX70 55 in. Rear Projection Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Toshiba 55HX70 55 in. Rear Projection Television
Key Features
Screen Size
55 inch
Audio Features
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Technical Features
Picture in Picture
With PIP
Toshiba Contact Information
Main support number800-457-7777
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
