Toshiba 51HX93 51 in. Rear Projection HDTV Television
Problems with Toshiba 51HX93 51 in. Rear Projection HDTV...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Toshiba 51HX93 51 in. Rear Projection...
Troubleshooting and Support
Solved Problems for Toshiba 51HX93 51 in. Rear Projection HDTV Television RSS Feed
View More Results for Toshiba 51HX93 51 in. Rear Projection HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Toshiba 51HX93 51 in. Rear Projection HDTV Television RSS Feed
Answer
we are on Dish network but the problem is that our DVD player locks up while we are trying watch... (More)
Answer
I have a Toshiba 51HX93 projection TV that has TV Guide On Screen. It does not retrieve listings;... (More)
Answer
speaker connection came off. can't find the four pin connector in the mother board. Same make and... (More)
Answer
When I push the power button, there is a click sound, but the TV will not come on. It there are fuse... (More)
Find a Manual
Toshiba 51HX93 51 in. Rear Projection HDTV Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Toshiba 51HX93 51 in. Rear Projection HDTV...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Toshiba 51HX93 51 in. Rear Projection HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Toshiba 51HX93 51 in. Rear Projection HDTV Television
Key Features
Screen Size
51 inch
Display Format
1080i (HDTV) · 480p (EDTV) · 480i (SDTV)
Digital TV Standard
HDTV
Display Capabilities
Aspect Ratio
16:9
Built-in Tuner
ATSC
Remote Control
Remote Control
Universal
Illuminated Remote
Illuminated
Image Quality
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Output
Variable / Fixed
Audio Type
Virtual Surround
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Technical Features
Picture in Picture
With PIP
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Commercial Skip
With Commercial Skip
Connectors
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1
Memory Card Slot
SD Card · SmartMedia Card
Screen Text
Channel Labels
With Channel Labels
Closed Caption on Mute
With Closed Caption On Mute
Dimensions
Depth
22.5 in.
Height
50.5 in.
Width
47.56 in.
Weight
169 lb.
Warranty
Overall Warranty
1 Year
Tube Warranty
2 Years
Toshiba Contact Information
Main support number800-457-7777
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
