I've owned a Toshiba 65HX83 for 5 yrs now and keep hearing I should replace the bulb to improve...
(More)
I've owned a Toshiba 65HX83 for 5 yrs now and keep hearing I should replace the bulb to improve quality since I probably have noticed the slow but steady decline of it. I can't seem to find an exact spec on which one I need.
I have a 65 inch Toshiba projection TV.. we have add it for about 6-7 yrs and the focus is starting...
(More)
I have a 65 inch Toshiba projection TV.. we have add it for about 6-7 yrs and the focus is starting to fade. If i put it on the HD station for about 10 min the focus comes back in and all channels are clear.. It seems like something is going or a focus needs to be re adjusted..please help
Have smears on the screen "Plastic" Face and can't seem to remove them. Manual does not...
(More)
Have smears on the screen "Plastic" Face and can't seem to remove them. Manual does not address how or what to use on the face. Tried vinegar and then water but ot no avail...
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
