Toshiba TheaterWide 46HM94 46 in. Rear Projection HDTV Television
Problems with Toshiba TheaterWide 46HM94 46 in. Rear Projection...?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Toshiba TheaterWide 46HM94 46 in. Rear...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Toshiba TheaterWide 46HM94 46 in. Rear Projection HDTV Television RSS Feed
View More Results for Toshiba TheaterWide 46HM94 46 in. Rear Projection HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Toshiba TheaterWide 46HM94 46 in. Rear Projection HDTV Television RSS Feed
Answer
picture goes to bright orange , red power light blinks , have to unplug to clear problem
Answer
u turn the tv on and it hase vertical fuzzy lines that distort the picture but it gets beter after... (More)
Answer
how can u tell if the power supply is going out?? it has a wavy piture when u turn it on but it... (More)
Answer
I was recently given a 46hm94 with what I was told was a failed lamp. After replacement I realized... (More)
Answer
I press the swith-on button at the front of the tv the red light comes on then i press the remote... (More)
Answer
Recently my cable company (a small local company) added more HD channels. Around this time, a... (More)
Answer
My tv makes a loud buzzing noise that goes in and out and gets louder and louder.
Find a Manual
Toshiba TheaterWide 46HM94 46 in. Rear Projection HDTV Television Manuals & Guides
Tips & Tricks
(Post a New Tip)
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
The Fl231 PROBLEM(CONVERGENCE NOT IN CUSTOMER MENU) ITC22 chasis
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and... written by willtab
Updated! Convergence Problems & Solutions - With example photos
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV... written by Ecollier2012
How To Fix A Convergence Problem
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen... written by Ecollier2012
Distorted Video - Convergence Problems - 3D Looking
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the... written by Ecollier2012
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for TheaterWide 46HM94 46 in. Rear Projection HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Rate and Review the Toshiba TheaterWide 46HM94 46 in. Rear Projection HDTV Television
Write a review:
Rate this product:
Would you recommend the TheaterWide 46HM94 46 in. Rear Projection HDTV Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Toshiba TheaterWide 46HM94 46 in. Rear Projection HDTV Television
Key Features
Screen Size
46 inch
Display Format
720p (HDTV)
Digital TV Standard
HDTV
Projector Technology
DLP
Display Capabilities
Aspect Ratio
16:9
Built-in Tuner
ATSC
Remote Control
Remote Control
Universal
Illuminated Remote
Illuminated
Image Quality
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Output
Variable / Fixed
Audio Type
Virtual Surround
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Technical Features
Picture in Picture
With PIP
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Connectors
Headphone Jack
Without Headphone Jack
Rear Input Connectors
Component x 2 · S-Video x 2 · Audio (RCA) x 2 · Composite x 2 · RF x 2 · HDMI x 1 · FireWire x 2
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1
Rear Output Connectors
Audio (RCA) x 1
Memory Card Slot
SD Card · SmartMedia Card · Memory Stick
Screen Text
OSD Languages
English · French · Spanish
Channel Labels
With Channel Labels
Closed Caption on Mute
With Closed Caption On Mute
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 20 Watt
Dimensions
Depth
15.25 in.
Height
31.81 in.
Width
53.13 in.
Weight
75 lb.
Toshiba Contact Information
Main support number800-457-7777
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
