I have a Toshiba 57h84 that the red light is flashing. When I unplugged it for a while then plugged...
(More)
I have a Toshiba 57h84 that the red light is flashing. When I unplugged it for a while then plugged it back in, the whole screen was greenish with a brown circle in the center. Then it shuts back off and the red light flashes again. This t.v is only 4 years old and I purchased it new. Any ideas out there????
Toshiba 57H84 no power, no picture, no sound.Please inform on power supply part damaged, part number...
(More)
Toshiba 57H84 no power, no picture, no sound.Please inform on power supply part damaged, part number is greatly appreciated. Thank you.
My screen will go green, the television will shut off and the little red button flashes on and off....
(More)
My screen will go green, the television will shut off and the little red button flashes on and off. I have to unplug it for a little bit, then it will be okay for a while. Does anybody know what the problem is?
My screen will go green then shut off. The little red button next to the power button blinks on and...
(More)
My screen will go green then shut off. The little red button next to the power button blinks on and off. You have to unplug it for a little bit, then it will run for a while before it does it again.
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
written by Ecollier2012
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
