20 Most Recent Pine Top Sales Top Sales 511-0057/2 Mini Solar Gutter Light Set, 2-Pack Questions & Answers
5answers
What kind of metal is best for roof flashing?
copper is a good metal for flashing because it is strong, malleable, and durable, but really any flat sheet of metal will do the trick
4/25/2024 6:36:44 AM • Roofing • Answered 2 hours ago
3answers
Water Leaks and Potential Chimney Flashing Issue on Older Roof
If it is near the chimney, it will almost certainly be the flashing although water normally runs down the internal brickwork as well. Unless the wet area is further down the slope from the chimney. Water always follows gravity but can be deviated by just a roof nail in the way. Another thing to check is that you haven't lost the capping shingle that folds over the top of the apex of the roof. That shingle is susceptible to wind damage.
4/22/2024 9:31:46 AM • Roofing • Answered 2 days ago
Choosing Between Fixing or Changing My Roof
You have to look at the expected life of the roofing shingles that were put on. Although they will often last a lot longer than the warranty, it does give some indication. The difference in warranty is based on the thickness. Wind can cause nail to tear out, or a shingle to slip. Those repairs are an easy fix, but it also depends on how many need fixing. The higher the number the more it leads to full replacement being the best option. ..
4/22/2024 6:18:00 AM • Roofing • Answered 3 days ago
2answers
Water leaks in garage roof
It sounds like the sheets were incorrectly installed. The nails should be in the higher section of the corrugated iron rather than the valley, the lower part. If it is in the lower part, it is constantly wet when it rains, so will leak. If you can identify which nails are leaking, clean that nail head and apply some silicone or spray with bitumastic sealer. If the roof is old, replace it. pre-drill the holes and use a small blob of silicone.
4/19/2024 5:22:41 AM • Roofing • Answered on Apr 19, 2024
4answers
Metal vs. asphalt shingles for residential roofing: which is better and why?
It depends on a variety of factors, including cost, longevity, style, and local climate. Metal is the most durable roofing material, but it can be quite expensive and is not suitable for certain architectural styles. Asphalt shingles are much more economical and typically last 20-30 years, depending on the climate and other external factors. In some climates, asphalt is still the preferred choice because it is better at resisting damage caused by extreme cold or snow. Ultimately, the best option will depend on personal preference and budget.
3/29/2024 3:36:19 PM • Roofing • Answered on Mar 29, 2024
New deck roof right at window sill.
Ask your local authority to send a building inspector. They will do it for free and will tell the builder what is wrong. You don't fix a problem like that by removing a windowsill. The roof should lead to just below a brick course and flashing should be inlet and cemented into that course of bricks. ..
3/24/2024 3:13:43 AM • Roofing • Answered on Mar 24, 2024
2answers
Integrating a Green Roof with a Rainwater Collection System
Put a layer of pea gravel and sand below the soil and angle the roof towards a standard roof eavestrough gutter that has a leaf filter membrane on top. It will wash out a little soil are first, but will run clear once stabilized. ..
3/23/2024 11:05:09 PM • Roofing • Answered on Mar 23, 2024
tip
Industrial shed
Building steel pre-engineering buildings are better than conventional buildings and it save time and money. https://www.kavyaroofing.com/
on Jul 13, 2022 • Roofing
What kind of roofing knee pads
Rather than knee pads, if you can't stay on your feet, the foam from couch cushions are the way to go. They don't slide on asphalt shingles, and are usually free. Just scoot around on your back side. Be careful of it rolling up though.
10/16/2021 3:31:22 AM • Roofing • Answered on Oct 16, 2021
2answers
Flash a metal roof to a wall
if its brick you can cut into it so you can tuck the flashing in and apply sealent and run the flashing on top of metal roofing apply sealent inbetween before screwing down.
6/29/2021 3:00:23 PM • Roofing • Answered on Jun 29, 2021
What kind of furring strips do I use on top of my garage when I lay down my metal roof
pressure treated 1x2 should be sufficient as long as you use proper fastening screws. And you make sure your screwing into the trusses
3/19/2017 9:05:08 AM • Roofing • Answered on Mar 19, 2017
What does it happen when my gutters get clogged up?
Hey Mark, Thanks a great questions I have been asked many times by other fellow Australians. So here's the deal. Clogged gutters are among the prime reasons for fires in both the residential and commercial real estate sector. Bush fires are a common and disastrous events in places like Australia where the climate is harsh. Even in Sydney, one of the most populated cities in the country, the temperature often exceeds the bearable maximum and the air humidity is at its lowest. Despite being a coastal city, it's a region where bush fires can occur and homeowners need to be aware of the techniques that must be applied during the seasonal temperature peaks. Reducing the dry vegetation around the property is an essential part of preventing any bush fire. Yet, there are many flammable materials and items which can be found outdoors and the clogged gutters are one of them.To prevent an unexpected ignition, homeowners should always keep their gutters dirt and grime-free. While it is recommended that the removal of leafs and dirt should be done by a professional gutter cleaning team, homeowners can do still do it themselves while following the local regulations. In Sydney, for example, there are specific rules for water use in Sydney and working from heights should be complied with the state's requirements.In severe situations with a high risks of a fire, gutters must be filled with water to provide additional security for the building. Keypoints Here are the prime reasons you should take care of your gutters:
  • to prevent water damage
  • to prevent fire harardz
  • to prevent pest infestations
Here's some additional useful information: https://www.workcover.nsw.gov.au/__data/assets/pdf_file/0015/15207/managing-the-risk-of-falls-at-workplaces-code-of-practice-July-2015-3566.pdf
2/19/2016 1:32:28 PM • Roofing • Answered on Feb 19, 2016
Is it possible to build your own gutters?
Technically it is possible to build your own gutter. I would do it using PVC piping. But frankly, I don't think it's worth it because getting the measurement exact could be a problem. Plus, PVC can be very heavy so you might not want to put that much strain on your roof.
4/15/2015 11:17:53 PM • Roofing • Answered on Apr 15, 2015
Need class a chimney flashing for penetration
Hello Stephen. I do understand what you are talking about with your flashing. Your supplier of the standing seam metal should have similar metal flashing to use on any of your roof flashing points. There is a process to install flashing on a chimney or any other protrusions, If you are still interested post some pictures of what you have and I will explain the best I can. It takes years of experience to do some flashings especially on standing seam metal.
2/13/2015 9:03:06 PM • Roofing • Answered on Feb 13, 2015
I need someone to come out and check my gutters. I think something might be rotting up there. I live in Denver.
Here is a company I found on Yelp with good ratings. They should be able to come out to your house and check out your gutters.
12/5/2014 2:28:10 AM • Roofing • Answered on Dec 05, 2014
2answers
My roof is only got a 10 degree pitch what would
You don't say what the problem is.
10/27/2014 11:17:11 AM • Roofing • Answered on Oct 27, 2014
2answers
Is it necessary to put flashing around the chimney?
absolutely, if you don't do it you will have to tear up the shingles later and put it in when the roof starts leaking around the chimney
9/26/2014 8:08:22 PM • Roofing • Answered on Sep 26, 2014
Water drainage runoff
Cement would work fine just make sure it's level and wAter can drain into it
7/25/2014 8:35:35 PM • Roofing • Answered on Jul 25, 2014
How work the laptop with the tv
To connect your computer to your tv you will need an rs-232 cable that is male at both ends and then change your TV's input to "PC" or "RGB"..
6/11/2014 10:35:11 AM • Roofing • Answered on Jun 11, 2014
Pine Top Sales Top Sales 511-0057/2 Mini Solar Gutter Light Set, 2-Pack Logo
1 questions posted
Top Pine Top Sales Roofing Experts
ADMIN Andrew
ADMIN Andrew
Robbie Goodwin
Steve Pack
Steve Pack
Are you a Pine Top Sales Roofing Expert? Answer questions, earn points and help others
View Most Popular
  • Pine Top Sales Roofing
Most Popular Question
choosing between fixing or changing roof
  • Roofing
