Home
My Products
Sign In
All Products
Omage
Home Theater Speakers and Subwoofers
Problems with Omage GR308 Main / Stereo Speaker?
Add to Warranty Manager
Search inside
Knowledgebase
Troubleshooting and Support
Post a New Problem
Should I play music using only the front...
Should I play music using only the front speakers?
1 Solution
My home theater system has surround sound,...
My home theater system has surround sound, but there isn't any sound coming from the center or surround speakers. What...
1 Solution
just got an infinity PERFECT 12.1 sub and...
just got an infinity PERFECT 12.1 sub and i have and mtx rt2200 amp. When ever I start to turn the gain up on the amp,...
1 Solution
No Woof
The Woofer on one of my speakers has no sound coming from it. I have them bi-wired so I switched cables and still the...
1 Solution
subwoofer
I have a Pioneer 5.1 receiver with an RCA female plugin for the output to the subwoofer. The subwoofer input does not...
1 Solution
cerwin vega ht-10d subwoofer won't work in...
we don't know which hole to put our ht-10d subwoofer (non powered) into our 6060 yamaha receiver.....HELP!!!!!PLEASE!!!!...
1 Solution
philips dvd sarround soud set up with pc
need to connect the saround sound system to my pc please diagram wiring and if need any specil cables.
1 Solution
View All
Tips & Tricks
Post a New Tip
Be the first to Post a New Tip
WikiManual
Post a New Chapter
Be the first to Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Be the First to upload Manual or Guide
Specifications
Key Features
Function
Main / Stereo
Nominal Power
85 Watt RMS
Cabling
Cable
Construction
2-Way
Technical Features
Peak Power Handling
125 Watt
Sensitivity
88 dB
Impedance
8 ohm
Frequency Reponse
28 Hz - 22,000 Hz
Components
Tweeter Size
1 "
Woofer Size
8 "
Design
Exterior Color
Black
Mounting
Floorstanding · On-Wall · Bookshelf
Outdoor/Indoor
Outdoor/Indoor
Dimensions
Depth
10.9 in.
Height
13.9 in.
Width
10.8 in.
Weight
19.9 Ib.
Sponsored Links
Avior
Let one of our
Experts Solve
your Problem
DO YOU WORK FOR
OMAGE
Register as STAFF
New Products
Powered by
Repair Service
Find Home Theater Spe. Repairman Near You:
Advertise Here
powered
by
Get this Widget
