Go into your video adapter settings and make sure that VSync is on, or that your refresh rate is equal to the max FPS your monitor supports.
Example:
If my monitor is 60hz, then I can only support up to 60FPS, and my refresh rate should be 60hz.
Manufacturer's Website: Go to the manufacturer's website (visit the official Samsung website in this case). Click on the support section, search your monitor model by product name or model number, and download your monitor model for the user manual. User manuals usually list codes and other relevant information.
User Manuals Online: Many people post user manuals online for all types of electronic devices and peripherals. You can search for your monitor and look for the user manual at sites such as ManualsLib, ManualsOnline, or Retrevo. Most of these sites will catalog user manuals for a wide variety of devices posted online by users and are normally free to access.
Physical User Manual: If you still have the original box or packaging with your monitor, there might be a copy of the user's manual in that box or enclosed. It might be in an actual printed booklet or perhaps just some links to online resources. Check under a section entitled 'Remote Control Codes' or 'Setup Instructions'.
Contact Samsung Support: If no luck finding it to download or to help you, there is contact support available, they should know where that information is, and be able to send it to you or refer you.
With these, you should be able to find the user manual for your Samsung 32" curved screen display and enter those codes.
ENGLISH ONLY please.
Samsung washing machine wf90f5e5u4w
Hello good afternoon, I want to ask for help, I have a faulty module and I wanted to ask if you have the electronic diagram for the Samsung DC92-01240C washing machine, the machine model wf90f5e5u4w, I would really appreciate it if you could, thank you. greetings Antonio Paulo
Sounds like the phone is on a contract with a different supplier.
Contact the original SIM supplier, EE, O2, Vodaphone etc and ask them to unblock the phone.
Question edited to add the further information.
Has to be in the manual? Did you pull the mains plug overnight?
That panel is called OSD (on screen display) and can be set to stay on for up to 200 seconds. Page 39 refers, and you can also reset it to factory defaults.
https://downloadcenter.samsung.com/content/UM/200803/20080329132905671_BN59-00716A-Eng.pdf
That sounds like a voice command problem for this Chicago, Illinois based channel. Refer to the station by its number on your subscription package, like "Alexa channel 1105 on tv".
https://www.google.com/search?q=wgn+-+tv
Samsunghttps://www.samsung.com > answer > ANS00087622
Amazon Alexa is now built-in on Samsung TVs and smart monitors! You can ask Alexa to change the channel, open apps, search for movies and shows, play music, ...
Tom's Guidehttps://www.tomsguide.com > How-to > TV
Apr 5, 2023 - Step 1: Set up your devices. First, make sure that both your Samsung TV and your Amazon Alexa device are set up and workings.
Can Alexa change TV channels? As long as you're using the TV's built-in tuner, you can use Alexa to change TV channels. Just say something like "Alexa, channel 7 on TV" or "Alexa, change channel to [channel name] on [TV name]."Nov 1, 2022
Plasma is old technology and it is 16 years old and made in Mexico, the worst place for quality control. It is time for a new one, or at least an upgrade. Or you can get a board kit and take a chance on fixing it.
Restart the system: Turn off the system and unplug it from the power source. Wait a few minutes, then plug it back in and turn it on.
Check the connections: Make sure all cables and connections are securely connected and not damaged.
Reset the system: Try resetting the system to its default settings. This can typically be done by pressing and holding the reset button on the back of the DVR for several seconds.
Update the firmware: Check if there are any firmware updates available for your system and install them if necessary. You can usually find firmware updates on the manufacturer's website.
Contact Samsung support: If none of these steps work, you may need to contact Samsung support for further assistance. They may be able to diagnose and resolve the issue or provide you with options for repair or replacement if necessary.
It's important to note that working with a security system can be sensitive and may require the assistance of a professional. If you are not comfortable troubleshooting the system yourself, it's recommended to contact a professional installer or Samsung support.
