20 Most Recent Toshiba 36AF61 36" TV Questions & Answers
Pin Cushion, someone is pulling your leg.
Toshiba 36AF61... | Answered on Oct 26, 2017
Hello
Please consult your user manual to get the required information you need,but if you look at your remote,you will see a button that has video written on it or AV.Your user manual should contain the required information anyway so do consult it
Toshiba 36AF61... | Answered on Jun 12, 2011
Unlikely to be a fuse, likely to be some capacitors and possibly semiconductors need changing in the power supply or line output section of the board.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Toshiba 36AF61... | Answered on Feb 26, 2011
your TV is having a power problem. The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the TV might not come on.
This problem may have occurred as a result of excess voltage entering into the TV, interrupted power supply, power surge, etc.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
Good luck.
Toshiba 36AF61... | Answered on Nov 26, 2010
how much power does my toshiba 35AF44 use??
Toshiba 36AF61... | Answered on Jul 21, 2010
its a prob of ic...u'll have to need of any elctrician
Toshiba 36AF61... | Answered on Feb 26, 2010
it sounds "TSIKKS"? observe first about 5 seconds, try to feel on your skin on the picturetube and you may feel static current or electricity, indicating that your television works!? try to plug cable, any vedeo inputs, but if not? then the power section maybe checked and replace the defective parts.
Toshiba 36AF61... | Answered on Jul 30, 2009
With it only being about 3 years old, I would suspect bad solder connections rather than defective components like Capacitors. You may get the symptoms to come and go by slapping the side of the set or jaring it slightly which would prove the bad connection thesis. It is not a permanent cure however and you can make it worse if you keep doing that. A solder repair shouldn't run over $225 in my opinion.
Toshiba 36AF61... | Answered on May 01, 2008
With the set being 12 years old, I'm sure the picture tube is near the end of its useful life. You probably have a defective semiconductor, either an IC or transistor that has gone up giving you no color, but with the green picture, it is not likely worth repair.
Toshiba 36AF61... | Answered on Apr 08, 2008
Hi.
Yes the dss module is very common to fail.
Unless you have proffesional soldering station & can work on ics whith 200 plus legs do not attempt to repair.
On ocaision if you moan to toshiba they will send A replacement module free of charge. I have had several come to our shop where Tosh has done this the module is just over £100.00 to buy.
All you need do then is pay to have it fitted saving over £100.00
Hope this helps
Chris.
http://dysonmanuals.llc.nu/index.htm
Toshiba 36AF61... | Answered on Mar 17, 2008
It is out there, that if you have internet enabled on the Toshiba BD player, did you need to stop or disable the internet capability.
Toshiba... | Answered on Jul 06, 2019
Toshiba 36AF61 36" TV Logo
16 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
toshiba 36zp38b
  • Televison & Video
