FixYa.com
Tamron 17-35mm f/2.8-4 Aspherical IF Autofocus Lens for Canon EOS
All Products > Tamron > Camera Lenses
Problems with Tamron 17-35mm f/2.8-4 Aspherical IF Autofocus Lens for Canon EOS?
Search inside Tamron 17-35mm f/2.8-4 Aspherical IF... Knowledgebase
Troubleshooting and Support
Solved Problems for Tamron 17-35mm f/2.8-4 Aspherical IF Autofocus Lens for Canon EOS RSS Feed Post a New Problem
My lens says "28 - 90mm D type...
My lens says "28 - 90mm D type Nikkor". What does that all mean?
1 Solution
Where should I focus my lens so I will get...
Where should I focus my lens so I will get everything from some close point to infinity in focus?
2 Solutions
A friend of mine gave me two of his lenses (80mm Mamiya Secor C and 150mm Mamiya Secor C) to look at because they have...
2 Solutions
lens calibration
1 Solution
Do UV filters work on digital?
In the comments in this picture the question is asked if the blue haze in the picture could be reduced and adds that in...
1 Solution
fixing a lens
i have a phoenix 100-400mm lens that got jarred. it won't come down past 200mm. i need to know if it fix able.
1 Solution
Camera lens focus problem
Photos from my lens are fine in about 70% of the area, but in the bottom left corner and up to maybe 1/3 of the height...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Focus TypeAutofocus
Lens MagnificationSuper Wide Angle (9 - 21mm)
Lens TypeZoom Lens
Camera Format35 mm SLR
Lens Max Aperturef/2.8-f/4
Focal Length17mm - 35mm
Macro LensWithout Macro Lens
MountCanon FD / FL
Other Features
Closest Focusing Distance11.8 in
Picture Angle63 - 104 degrees
Attachment / Filter Size77 mm
Groups / Elements14 Elements in 11 Groups
Diaphragm Blades7 Blades
Designed for Digital CameraYes
Weight
Weight14.4 oz
Dimensions
Length3.4 in
Diameter3.3 in
Tamron Contact Information
Main support number800-827-8880
Support FAX631-543-5666
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
