FixYa.com
Tamron 28-300mm f/3.5-6.3 DI XR for Canon
All Products > Tamron > Camera Lenses
Problems with Tamron 28-300mm f/3.5-6.3 DI XR for Canon?
Search inside Tamron 28-300mm f/3.5-6.3 DI XR for... Knowledgebase
Troubleshooting and Support
Solved Problems for Tamron 28-300mm f/3.5-6.3 DI XR for Canon RSS Feed Post a New Problem
will not autofocus
I have been using a Tamron 28-300mm lens with a Canon XTi. Thing have been working fine until the last time I used the...
1 Solution
the part that locks the lens to the camera has broken I have taken it off but i cant find a replacement part anywhere...
1 Solution
Tamron 28-300 mm f/3.5-6.3 LD IF - rear...
The rear piece that mounts on 3 small screws is broken and finally got seperated. Is it possible to buy just this piece...
1 Solution
dropped camera and what broke was the rim...
The small arms that screw into the lesnse holding this rim in place broke as theyare plastic, how would I get another...
1 Solution
tamron 28-300mm lens disassembly help
Do you disassemble the 28-300 tamron lens form the front? I have read thru the post and seems like conflicting answers....
1 Solution
Tamron 28-300 loose lens parts
Can I take this apart and attempt to fix it myself? Tamron wants $100 to send it in and fix it, thus its cheaper to buy...
1 Solution
When my I tilt my Nikon d-80 forward, the Tamron 28-300mm lens slides open?! Or it falls to the fully extended position...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Focus TypeAutofocus
Min Aperturef/22
Lens MagnificationWide Angle (21 - 35mm), Normal / Straight (35 - 65mm), Telephoto (65 to 600mm)
Lens TypeZoom Lens
Camera Format35 mm SLR
Lens Max Aperturef/3.5-f/6.3
Focal Length28mm - 300mm
Macro LensWithout Macro Lens
MountCanon EF
Other Features
Closest Focusing Distance19.3 in
Picture Angle8 - 75 degrees
Attachment / Filter Size62 mm
Groups / Elements15 Elements in 13 Groups
Diaphragm Blades9 Blades
Designed for Digital CameraYes
Weight
Weight14.8 oz
Dimensions
Length3.3 in
Diameter2.9 in
Tamron Contact Information
Main support number800-827-8880
Support FAX631-543-5666
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
