FixYa.com
Toshiba 36A50 36" TV
All Products > Toshiba > Standard Televisions
Problems with Toshiba 36A50 36" TV?
Troubleshooting and Support
Solved Problems for Toshiba 36A50 36" TV RSS Feed Post a New Problem
Toshiba 36A50 Horizontal Line
Over the last three months, the image slowly compressed from bottom and top. Earlier, I could leave the TV on for a few...
1 Solution
36" 36a50 tv won't turn on
When TV is turned on, it does not come on. Red light at on switch flashes off and on in a sequence, but picture does not...
1 Solution
Analog odr Digital?
Power supply is going. Picture shrinks and if you bang the top of Tv picture fills out fully. With all siginals going...
1 Solution
codes to make my Time warner remote...
Can I get a list of codes to enter in to my remote, so the Time Warner Cable remote will control the tv?
2 Solutions
vertical size of picture
the picture will be fine then a line starts flashing at the bottom the picture then the picture gets shorter vertically...
1 Solution
solution
Hi me name its ivan i hawe problem vith my tv toshiba colour tv model no;2939db.i don t hawet the orginal remote i haw...
1 Solution
toshiba pip
I have a toshiba 36A50 but i have lost the original remote control.. I use my dishnetwork remote now......do i need the...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Toshiba 36A50 36" TV RSS Feed Post a New Problem
36A50 flicking on/off
We noticed the TV is flickering on/off as per the front power LED. Sometimes the LED will flash @ 1Hz while not...
Post a Solution
Picture too dark
My 36"toshiba picture is too dark, Even with the highest brightness, its still too dark when the background is...
Post a Solution
cannot program any universal converter for...
Original converter broken, bought several universal converters but none will program. tried all codes and automatic...
Post a Solution
no vertical output
there is only a thin line across the screen, could use a schematic of chassis and possible causes tu
Post a Solution
TV wont read any of my game consoles input...
I cant play my game console anymore on the TV. For some reason the TV doesnt seem to be accepting the signal coming from...
Post a Solution
I F detect for sound
I have Toshiba T V 32" model no 8272b, I want to go to service mode to make some changes on the IF 6.0 to IF 5.5 so...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Diagonal Screen Size36 inch
Audio Features
SAP / MTS StereoSAP / MTS Stereo
Technical Features
Picture in PictureWith PIP
Toshiba Contact Information
Main support number800-457-7777
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
