FixYa.com
Tamron 18-200mm f/3.5-6.3 for Nikon
All Products > Tamron > Camera Lenses
Problems with Tamron 18-200mm f/3.5-6.3 for Nikon?
Search inside Tamron 18-200mm f/3.5-6.3 for Nikon Knowledgebase
Troubleshooting and Support
Solved Problems for Tamron 18-200mm f/3.5-6.3 for Nikon RSS Feed Post a New Problem
tamron18-200 f/3.5-6.3
I can't adjust the aperture to 3.5 even thought the focal lenght is 18mm, the max aperture is only f/6 i'm using nikon...
1 Solution
pentax K1000 camera
I have a 25 yr old camera Asahi Pentax K1000 , Need to know a reliable source where i can get the lenses cleaned and...
1 Solution
nikon lens problem
hi, i have problem wit my nikon coolpix5900.it met wit an accident n since then its lens isn't coming out on putting the...
1 Solution
mounting a teleconverter on a minolta...
I have a Minolta maxxum 300si and it came with a tamron mc teleconverter 2x for minolta md. Do I need any other hardware...
1 Solution
fujifim finepix f11
Fujifilm f11 camera won't switch on, battery has been charged and is in the right way. Have just returned from sub zero...
1 Solution
my motorola slvr L7
my motorola slvr L7 camera and vireo wont open its say busy try again later what maybe the problem pls help
1 Solution
My lens says "28 - 90mm D type...
My lens says "28 - 90mm D type Nikkor". What does that all mean?
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Tamron 18-200mm f/3.5-6.3 for Nikon RSS Feed Post a New Problem
lens not mounted...
I have  a nikon d60 and a tamron af18- 200mm f3.5-6.3 xr diII lens. From time to time, the autofocus will not work...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Focus TypeAutofocus
Min Aperturef/22
Lens MagnificationSuper Wide Angle (9 - 21mm), Wide Angle (21 - 35mm), Normal / Straight (35 - 65mm), Telephoto (65 to 600mm)
Lens TypeZoom Lens
Camera FormatDigital SLR
Lens Max Aperturef/3.5-f/6.3
Focal Length18mm - 200mm
Macro LensWithout Macro Lens
MountNikon
Macro Magnificationx 3.7
Other Features
Closest Focusing Distance17.7 in
Picture Angle7 - 75 degrees
Attachment / Filter Size62 mm
Groups / Elements15 Elements in 13 Groups
Designed for Digital CameraYes
Weight
Weight14 oz
Dimensions
Length3.3 in
Diameter2.9 in
Tamron Contact Information
Main support number800-827-8880
Support FAX631-543-5666
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
