20 Most Recent Efco 18" 51.7cc Gas Chain Saw - 152-18 Questions & Answers
My efco 152 chain saw tickes over , but when I reve it up it holds back
If the exhaust is smoky turn the needle valve marked with an H in (clockwise) about 1/8 of a turn. If not turn it out 1/8. If the fuel in it is older than a month Dump it out and start with fresh fuel before adjusting the needle valve.
3/3/2015 11:17:54 PM • Efco 18" 51.7cc... • Answered on Mar 03, 2015
Efco 8260 dont want to start after running it
ignition coil may be getting bad. check spark when it acts up.
10/11/2019 6:42:56 PM • Efco Garden • Answered on Oct 11, 2019
How do i replace the fuel lines in my efco 8725 trimmer
Please be more specific, are the lines gone? If not just route the new ones exactly like the old lines are routed. What is the issue with the fuel lines anyway?
4/26/2019 1:17:53 AM • Efco Garden • Answered on Apr 26, 2019
Efco 181 chainsaw gas keeps running when engine is off
Carb issue. New carb is probably cheap on amazon. Sounds like a busted diaphragm.
2/7/2019 11:30:11 PM • Efco Garden • Answered on Feb 07, 2019
How do i solve the pull cord jammed on my grass strimmer, efco stark 2500s
remove cover and replace string or repair
7/17/2018 7:03:46 PM • Efco Garden • Answered on Jul 17, 2018
What is the fuel mix for efco tg2600xp
25:1CAUTION: DO NOT USE AUTOMOTIVE OIL OR 2-CYCLE OUTBOARD OIL
7/30/2017 8:33:15 AM • Efco Garden • Answered on Jul 30, 2017
Which spark plug do I need for this machine?
which machine... Safe bet NGK BPMR7A
4/28/2015 1:32:05 AM • Efco Garden • Answered on Apr 28, 2015
Fuel not getting to carb ???
I'd start with looking at the fuel filter.
3/16/2015 1:37:09 PM • Efco Garden • Answered on Mar 16, 2015
0answers
0answers
The Casino I work at
Working at a Casino: Since you haven't specified a particular question or topic about working at a casino, I'll provide some general information and potential areas you might be interested in: Casino Job Roles: Gaming/Dealers: This includes roles like blackjack dealers, poker dealers, roulette dealers, craps dealers, and more. These positions require specific skills and knowledge of the games they operate. Security: Casino security personnel ensure the safety of guests and employees, monitor for suspicious activity, and enforce casino regulations. Surveillance: Surveillance operators use cameras and other technology to monitor all areas of the casino and identify potential security risks or cheating. Food and Beverage: This includes roles in restaurants, bars, and other food service outlets within the casino. Customer Service: Casino hosts, cashiers, and guest services representatives interact with guests, provide information, and resolve issues. Management: Casino managers oversee various departments, ensure smooth operations, and manage staff. Aspects of Casino Work: Customer Interaction: Many casino jobs involve direct interaction with guests, requiring excellent communication and interpersonal skills. Fast-Paced Environment: Casinos are often busy and energetic, requiring employees to be adaptable and able to handle pressure. Shift Work: Casinos operate 24/7, so employees may work nights, weekends, and holidays. Regulations and Compliance: The casino industry is heavily regulated, and employees need to be aware of and adhere to various rules and procedures. Security and Safety: Security is a top priority in casinos, and employees play a role in maintaining a safe environment for guests and colleagues. Potential Areas of Interest: Career Development: Many casinos offer opportunities for growth and advancement within the organization. Training and Certification: Depending on the specific job role, training or certification may be required. Compensation and Benefits: Casino employees typically receive competitive wages and benefits packages. Challenges and Rewards: Working in a casino can be both challenging and rewarding, offering unique experiences and opportunities to interact with diverse people.
4/23/2024 9:46:10 PM • Garden • Answered 10 hours ago
Parts diagram for wall kennel pro model 8800
It looks like you meant 'Wahl', this is why upper case letters are important for 'proper names' because Spell check won't alter them. Here are the parts diagram and suppliers, including Wahl themselves. https://www.google.com/search?q=wahl+kennel+pro+model+8800+parts+diagram You can safely ignore the answer from the African Prince as he is just copying and pasting from AI Chat GPT4. ..
4/23/2024 9:17:53 PM • Garden • Answered 10 hours ago
I've a 5 litre garden pressure sprayer and it's not functioning properly. It is pumping pressure but then it's leaking it all out at top of the green handle.
Here are some steps you can follow: Check the Seals and O-Rings: Release the pressure: Make sure there's no pressure in the cylinder by releasing the pressure release valve. Unscrew the pump: Remove the pump to access the internal components. Inspect the seals and O-rings: Look for any damaged or worn-out rubber seals. Check the rubber seal at the bottom of the tube (where the plunger sits) and ensure it's in place. Examine the one-way valve (usually at the bottom of the tube) and clean it. Lubricate it with silicone grease. Lubricate the rubber washer on the plunger with silicone grease and reassemble it in the tube. Reassemble the pump: Put the plunger back into the tube and lock it with the handle. Test the sprayer: Pump it up and check if it maintains pressure without leaking. Inspect the Handle and Hose: Handle connection: Ensure the handle is securely attached to the cylinder. Hose inspection: Check the hose for kinks, twists, or blockages. Straighten out any kinks and remove debris that might be blocking the hose. Check the Nozzle and Wand: Nozzle adjustment: Adjust the nozzle to the desired spray pattern. Wand inspection: Examine the spray wand for clogs or obstructions. Lubricate O-Rings and Seals: Apply silicone grease to the O-rings, seals, and other moving parts to ensure smooth operation. Test the Sprayer: Fill the cylinder to the desired level (avoid exceeding the maximum fill mark). Screw down the pump firmly to create an airtight seal. Manually operate the pressure release valve to ensure it's working.
4/23/2024 5:45:51 PM • Garden • Answered 14 hours ago
2answers
Is weed membrane fabric any good for applying to stone driveway
Ensure the membrane is protected with sand before laying the stone to avoid piercing the membrane.
4/23/2024 12:28:45 PM • Garden • Answered 19 hours ago
2answers
What are the top advantages of online flower delivery services?
As a customer, the advantage is that I don't have to drive to the florist. Saves time and gas. I could make a phone call, but then I wouldn't see the available flowers.
4/23/2024 10:14:23 AM • Garden • Answered 21 hours ago
What is the transportation ring on a huskvarna chain saw
The transportation ring on a Husqvarna chainsaw is a small metal ring that is sometimes fitted onto one of the bolts when the saw is new. Its purpose is to prevent the chain from rotating during transportation or storage. If your chainsaw has this ring, you should remove it before using the saw. Keep it in a safe place so you can use it again if needed. If you're looking for more information about Husqvarna chainsaws, you can refer to the operator's manual for detailed instructions. https://www.manualslib.com/manual/3145215/Husqvarna-440.html
4/20/2024 9:45:09 PM • Garden • Answered 3 days ago
HPB18 3.6Ah 18Volt Replacement for Black and Decker 18V Battery can this stay on the charging unit in between use?
Yes, you can leave it on the charger. Modern chargers are designed to handle this, and it won’t harm the battery. However, it’s a good practice to remove the battery once it’s fully charged to prevent overcharging, especially if you won’t be using the tool for an extended period.
Remember to follow the manufacturer’s guidelines for optimal battery care, and enjoy the enhanced performance of your Black and Decker tools!
4/19/2024 6:17:32 PM • Garden • Answered on Apr 19, 2024
Efco 18" 51.7cc Gas Chain Saw - 152-18 Logo
1 questions posted
Top Efco Garden Experts
Jay Finke
Jay Finke
john h
Are you an Efco Garden Expert? Answer questions, earn points and help others
View Most Popular
Efco Garden
  • Efco Garden
Most Popular Question
efco 152 chain saw tickes over but
  • Garden
