Toshiba 32HF73 32" TV
Problems with Toshiba 32HF73 32" TV?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Troubleshooting and Support
Solved Problems for Toshiba 32HF73 32" TV RSS Feed
Click here to get instant support from our best Experts!
View More Results for Toshiba 32HF73 32" TV
Questions and Unsolved Support Problems
Unsolved Problems for Toshiba 32HF73 32" TV RSS Feed
Answer
When I turn TV on I get a few seconds of sound then a bright flash at the top of the screen as the... (More)
Answer
Audio ports on front of tv are input only. There are no available output ports on the back of the TV... (More)
Answer
i have replaced flyback and still have a blurry pic and need some help
Answer
Never had any problems with this tv until I woke up one morning and turned it on only to see a... (More)
Find a Manual
Toshiba 32HF73 32" TV Manuals & Guides
WikiManual
(Post a New Chapter)
How to Repair a Remote Control
Don't put up with your faulty buttons on you Remote Control anymore! If some of the keys on your remote have stopped working or you have to push... by wikihow
Upload Manuals
Tips & How To Guides for the Toshiba 32HF73 32" TV
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
My Magnavox TV is showing a feature screen
Press the channel up and volume down buttons at the same time on the front of the tv until the set goes off. When you turn the set back on the feature... written by rusty_etech
Magnetized TV, Poor picture, blotches, discolored, target shaped image
If your set looks like the one pictured above it is likely magnetized and needs to be degaussed (or demagnetizing). All CRT type TV's are prone to... written by johnnydiode
Help FixYa, Help you and help others. Share your User maunals and...
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for... written by stoneheaded
DTV transition: Options for Those with Analog TVs
On Feb 18, US viewers with analog TVs will no longer receive free over-the-air programming. In other words, if you've got an older TV with rabbit ear... written by Lauren_FixYa
Removing parental lock on RCA and GE TV sets
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method... written by techman
repair job update
Update A number of people have commented that after changing the color wheel, their red and blue colors are reversed. This is a different color... written by sweet_rascal
repair job continued
7. Locate the color wheel cover. It?s got a small green circuit board on top of it with a black/blue wires connected to it. Remove that plug. Also,... written by sweet_rascal
Purchase a Color Wheel & The Repair Job
My television is model Samsung HLM4365WX and the color wheel part number for that is BP96-00250A. This color wheel is used in many, many Samsung... written by sweet_rascal
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for Toshiba 32HF73 32" TV
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Toshiba 32HF73 32" TV
Key Features
Screen Type
Flat Screen
Diagonal Screen Size
32 inch
Digital TV Standard
HDTV-Ready
Display Capabilities
Aspect Ratio
16:9
Built-in Tuner
NTSC
Broadcast Format Supported
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Remote Control
Remote Control
Universal
Illuminated Remote
Illuminated
Image Quality
Invar Shadow Mask
With Invar Shadow Mask
Velocity Scan Modulation
With VSM
Comb Filter
3DYC / 3D Digital
Audio Features
Audio Output
Variable / Fixed
Audio Type
Stereo
Sound Leveler
With Audio Leveler
SAP / MTS Stereo
SAP / MTS Stereo
Technical Features
Picture in Picture
With PIP
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Energy Star Compliant
Connectors
Headphone Jack
Without Headphone Jack
Rear Input Connectors
Component x 2 · S-Video x 2 · DVI x 1 · Audio (RCA) x 5 · Composite x 2 · RF x 2
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1
Rear Output Connectors
Composite x 1 · RF x 1 · Audio (RCA) x 2
Screen Text
OSD Languages
English · French · Spanish
Channel Labels
With Channel Labels
Closed Caption on Mute
With Closed Caption On Mute
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 10 Watt
Dimensions
Depth
22.63 in.
Height
26.5 in.
Width
34.5 in.
Weight
147 lb.
Warranty
Overall Warranty
1 Year
Tube Warranty
2 Years
Toshiba Contact Information
Main support number800-457-7777
Describe your problem:
Top Standard... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
