I have a Toshiba TV model 36A43 that won't power on. The same thing happened yeaterday as this...
(More)
I have a Toshiba TV model 36A43 that won't power on. The same thing happened yeaterday as this morning. The tv will not power on via remote, or the manual power button. Yesterday, the same thing occurred and I unplugged it for a little while and then it worked. The picture was perfect as usual, but the volume down display kept popping up on the tv. I have the unit connected through a stereo system, so I don't even use the tv speakers, but the pop up was a bit annoying. I shut it off last night and this morning it won't power up again. I noticed today that when I unplug and plug it back in the red power indicator button flashes, but it won't turn on even after being unplugged for a couple of hours now.
The menu keeps coming up every few seconds and changing options on it's own. Like someone is using...
(More)
The menu keeps coming up every few seconds and changing options on it's own. Like someone is using the remote, but the actual remote is unresponsive.
Our Toshiba 36A43 was just repaired. A new power supply was put in, bring home and volume goes down...
(More)
Our Toshiba 36A43 was just repaired. A new power supply was put in, bring home and volume goes down to 0. Bring back up ,goes back down. Is this part of the power supply kit I paid for?. Ive put in $194. already. Kathy
Cannot turn channels, or volume. Menu keeps popping up, at short intervals it states, This programs...
(More)
Cannot turn channels, or volume. Menu keeps popping up, at short intervals it states, This programs exceeds limits, hit mute to key pin, then goes back to program.
I do't have the original control and it has to be on channel 73 for my satelite to show, what can I...
(More)
I do't have the original control and it has to be on channel 73 for my satelite to show, what can I do?
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
On Feb 18, US viewers with analog TVs will no longer receive free over-the-air programming. In other words, if you've got an older TV with rabbit ear...
written by Lauren_FixYa
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method...
written by techman
Update
A number of people have commented that after changing the color wheel,
their red and blue colors are reversed. This is a different color...
written by sweet_rascal
7. Locate the color wheel cover. It?s got a small green circuit
board on top of it with a black/blue wires connected to it. Remove that
plug. Also,...
My television is model Samsung HLM4365WX and the color wheel part
number for that is BP96-00250A. This color wheel is used in many, many
Samsung...
I?ve got one of the early models of the Samsung 43′ DLP Television
sets. We?ve been through a lot together, but it?s just a...
Don't put up with your faulty buttons on you Remote Control anymore! If some of the keys on your remote have stopped working or you have to push...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
