FixYa.com
Olicom CrossFire OC-8012 Router
All Products > Olicom > Routers
Problems with Olicom CrossFire OC-8012 Router?
Search inside Olicom CrossFire OC-8012 Router Knowledgebase
Troubleshooting and Support
Solved Problems for Olicom CrossFire OC-8012 Router RSS Feed Post a New Problem
How do I allow inbound traffic (run...
How do I allow inbound traffic (run servers) behind NAT?
1 Solution
When I install a new router it won't...
When I install a new router it won't connect to the internet ?
1 Solution
Router blocks internet access after a...
Hi, The router works fine for both wired and wireless connections for the first few minutes. But after a while...
1 Solution
wireless router dropping then disappeared
I connected my windows laptop to the wireless network, it worked ok, but kept dropping the signal, even when i moved to...
1 Solution
Dell TrueMobile 2300 Wireless Router
My truemobile 2300 router is not performing correctly. As of this moment all I get is orange led lights. I am curious...
1 Solution
No connection to internet
i have an MSI RG54G3 router and it worked perfect for a month; and then it stop working, i mean it works and i can...
1 Solution
wep/wpa
how do i figure out what is the proper wep wpa to put down to log onto the internet. we can not figure this part out.
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Memory
Installed RAM16 MB
Installed Flash Memory1 MB · 4 MB
Dimensions
Depth13 in.
Height3.94 in.
Width17.53 in.
Weight7.94 lb.
Supported Models
80120001, 80120003, 80120013, 80120039, 80120048, 80120050, 80120058, 80120081, 80120126, 80120194, 80120654, 80121525, 80121529, 80121571, 80121573, 80121578, 80121581, 80121604, 80121605, 80123223, 80124735, 80129561, 80129630
Olicom Contact Information
Main support number1 972-301-4688
Support FAX1 972-301-4689
Email supportjhog@olicom.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
