20 Most Recent Panasonic NV-DX110 Questions & Answers
We do not have code lists, use the code search function of the remote.
Panasonic... | Answered on Feb 07, 2019
No one sells a suggested replacement, as I like to say "anything can be fixed" so as a non suggested solution to your problem. I could not get an accurate representation on the net but you can replace the battery once you open it to see what the size (dimensions) and specs (voltage and amperage), then at which point we can find someone that makes the battery that would be compatible with that unit. You can also pay a local repair guy to do it. Because none of this is cost effective I'm gonna say just replace it but if you must keep it, that should get you in the right direction. good luck
https://www.6ya.com/mr.mike
Panasonic... | Answered on Feb 02, 2019
You may have a set that is Japanese only. Also Panasonic seem to think that model doesn't exist!
http://help.panasonic.ca/english/support/operatinginstructions/Results.asp
Also read this
http://www.fixya.com/support/t26265205-change_language_from_japanese_english_in
Electronics Technician: Russell H., Service Tech replied 3 years ago smile4large500by500.64x64.gif Russell H., Service Tech Category: Consumer Electronics Satisfied Customers: 13,855 Experience: 8+ years of professional experience verified.svgVerified Hi, thank you for contacting JustAnswer.com. My name is Russell. I will do my best to provide the right answer to your question.
That depends upon the exact model of Strada that you have.
If it is a CN-NVD905U, then that has only three languages: English, French, and Spanish. (So if it is in Japanese, presumably you don't have that model.)
I suspect you may have acquired a Japanese (-and-Korean-and-perhaps-Chinese) -language-only model.
But in any case, language changing is usually the first screen on initial setup. If you get a screen of language with two buttons, on the lower left and on the lower right, you probably should select the left-hand button, then select one of (possibly three) languages. English being predominant, the left-most button of three would be one to choose, if you have a model that can be set to English at all.
The initial setup screen with language choices, will probably be what you get once you reset the device to factory settings.
But tell me the exact and full model #, and I will research further, specifically to that model #. Ask Your Own Consumer Electronics QuestionType your question here... Customer reply replied 3 years ago The model # ***** ***** smile4large500by500.64x64.gif Electronics Technician: Russell H., Service Tech replied 3 years ago I cannot find any definitive references to language for that model. But: most (by far) of the pages that reference it are in oriental or Japanese characters! (kanji, that is.)
So I surmise it is a Japanese-language-only (with perhaps Korean and Chinese as alternate settings.)
Try a reset, select the left button of two on the screen that appears, then try each of the three (?) language choices after that, to see if any of them are in English.
After that, conclude that it is Japanese-(or Korean or Chinese-)only, period.
Panasonic... | Answered on Jan 23, 2019
Ask Panasonic
Panasonic... | Answered on Jan 18, 2019
You are not putting it in correctly. In one way it will only go partially into place and will not allow you to close the battery door. turn it around and it will lock into place. Look in the hole for the contacts and make sure the battery contacts are in the same alignment.
There are exceptions to this. For example, adjusting the White Balance is not available in the 4K Photo mode. See page 197 of the Advanced User Manual: ftp://ftp.panasonic.com/camera/om/dmc-zs60_adv_en_om.pdf .
I hope this helps.
Panasonic... | Answered on Jan 06, 2019
Try setting the top dial to P, A, S or M and see if that helps. You should be pressing the fat silver button that is inside the zoom control ring on top of the camera. If it still won't work, can't help but think this is something confounding but simple and if that is the case, ask for help in any camera store. Tell them you can't shoot a still photo and see if they can't figure it out.
It is awful trying to shoot with equipment that won't work right. Hope you have figured this out long before now.
Panasonic... | Answered on Jan 02, 2019
Take it to a Car Radio Specialist.
Panasonic... | Answered on Dec 05, 2018
You might try saving your psd file somewhere else, and try deleting it.
Panasonic... | Answered on Nov 28, 2018
Sounds like a faulty circuit board.
if it's an old camera it will not be cost affective the send it in for fixing.
Panasonic... | Answered on Nov 10, 2018
Panasonic Lumix cameras have some of the best video recording features on the market. most Notably on the GH2, GH3, GH4, G6 , and the FZ1000.
Panasonic... | Answered on Oct 08, 2018
You can get the manuals and other info on the camera here:
NEW LUMIX DMC ZS15 12 1 Megapixel Digital Camera
Panasonic... | Answered on Sep 25, 2018
This forum is for Cameras - please repost in a more appropriate forum. Thank you.
Panasonic... | Answered on Sep 10, 2018
Panasonic NV-DX110 Logo
Popular Tags
0 questions posted
Top Panasonic Cameras Experts
skyblue007
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Panasonic Cameras
  • Panasonic Cameras
Most Popular Question
just purchased new panasonic lumix fz80
  • Cameras
