Sony VPL HS1 Multimedia Projector
Problems with Sony VPL HS1 Multimedia Projector?
Troubleshooting and Support
Solved Problems for Sony VPL HS1 Multimedia Projector RSS Feed Post a New Problem
Sony VPL-HS1 Problem
Hi, having a problem with my vpl-hs1, am ready to send it in for service but I figured I'd ask here first and see if...
5 Solutions
LCD shutting off automatically
I use a Benq LCD projector to give powerpoint presentations. Lately the projector shuts down shortly after powering up....
1 Solution
paint your website area by giving...
how can you paint your website area by giving coordinates ?
1 Solution
In Focus X2 projector won't display...
In Focus X2 projector won't display welcome screen. It turns on, the fan goes on too and the green light is steady. I...
1 Solution
White vertical line in the center of...
We have had our X2 for about 3.5 years and not changed the bulb out. Within the last two weeks, a vwrtical white line,...
1 Solution
InFoucus LP500 Projector
My InFocus LP500 projector has a pinkest image when connected to the Dell C840 laptop. I have update the display driver...
1 Solution
SMALL ICON APPEARS ON THE SCREEN (TOP...
USUNG A TOSHIBA PROJECTOR MODEL TLP X3000 AND WHEN WE USE THE REMOTE TO MAKE THE PROJECTORED IMAGE LARGER A SMALL X IN...
1 Solution
Unsolved Support Problems
Unsolved Problems for Sony VPL HS1 Multimedia Projector RSS Feed Post a New Problem
VPL HS1
I connected the power cable (Beamer --> electricity network) nothing happened. The LED doesn't light red. The power...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
PlatformPC
TypeLCD Projector
Form FactorPortable
Display TechnologyTFT Active Matrix
Image Brightness700 ANSI lumens
Max Resolution (Native)800 x 600
Image Aspect Ratio4:3 (Standard) · 16:9 (Wide Screen)
Image Size (Diagonal)40 in. - 150 in.
Screen Distance5.25 ft. - 22.31 ft.
Synchronization Range Horizontal19 - 72 kHz
Synchronization Range Vertical48 - 92 Hz
Technical Features
Audio OutputSpeaker(s)
Operation Noise30 dB
Remote Control FeaturesIlluminated Remote
Interfaces
InterfaceRS232C (mini DIN-8 pin)
Video Input4 Pin - Mini DIN (S-Video) · Composite Video
Lamp
Lamp TypeUHP
Light Source Life2000 Hours
Light Source Power120W UHP
Other Features
Special FeaturesKeystone Correction
Speakers Output2 W
Projection MethodRear · Front · Ceiling
Standards
Analog Video FormatNTSC · PAL · PAL-M · PAL-N · SECAM · NTSC 4.43 · NTSC 3.58
HDTV Formats720p · 1080i · 480p · 480i
Dimensions
Depth11.82 in.
Height6.07 in.
Width13.4 in.
Weight8.6 lb.
Sony Contact Information
Main support number800-488-7669
Sponsored Links
Loading problems.
Top Experts
Ask Me
Marrie Wiz
15 solutions
Ask Me
marsrover Wiz
4 solutions
Ask Me
shadow559 Wiz
1 solutions
Repair Service
Find Multimedia Pro. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
