20 Most Recent Toshiba MW30G71 30 in. TV/VCR/DVD Combo Questions & Answers
unplug the television and hit the power button to make sure the cpacitors are drained then let it sit for 2-3 hours before plugging it back in, this should alow ample time for the memory to be lost.
Toshiba MW30G71... | Answered on Jun 30, 2011
The DVD player is region locked and will only play DVDs from a particular region. The cheap DVDs are probably region 0 and so will work on any DVD player. You can scour the internet for a code hack to change the region (I've had a quick look and not found anything).
Toshiba MW30G71... | Answered on Feb 20, 2011
Unplug the TV ...wait 30 seconds then plug back in. Worked fine.
Toshiba MW30G71... | Answered on Jul 21, 2010
Hi, If after trying the TV again later and problem persist, repairs are in order. A high pitched whine is an indication of a fault at the horizontal section of your TV. The horizontal provides the high voltage for the picture tube. Your best bet maybe to seek the services of a qualified professional TV repairman since this involves component level repair, soldering/desoldering, use of soldering iron and VOM (testers) and knowledge of circuitry. Good luck and kind regards.
Toshiba MW30G71... | Answered on Feb 22, 2010
same problem piece of junk
Toshiba MW30G71... | Answered on Nov 06, 2009
Picture tube issue. How long have you had it? Call the manufactor.
Toshiba MW30G71... | Answered on Jan 03, 2008
The TV is in the DEMO mode. Many sets have a demo mode, and they are all turned on and off differently. I do not recall exactly how it is done on the Toshiba, but if you look in your owner's manual or go through all pages of the menu, you should be able to find the option for demo mode and be able to turn it off.
Toshiba MW30G71... | Answered on Aug 29, 2007
dont know how to tern on a tv, I do know how to TURN on a TV though...
Toshiba MW30G71... | Answered on Jul 27, 2007
Not certain about this, try tapping MENU on your remote control, select SETTINGS then LANGUAGE.
Toshiba... | Answered 3 days ago
I plug headet in the service use only of my TV toshiba model 24HV1OE and something went wrong .what should I do to fix it?
Toshiba... | Answered on May 18, 2019
Hi Daren, it's a very strange fault, the one you mention
I sent you a link that talks about a similar failure on a Toshiba TV
I hope it will help you and you can solve the problem
But I suggest you look for a specialized technical service
Greetings Franco Dosil
Hola Daren, es una falla muy extra?a, la que comentas
Te envio un link que habla de una falla parecida en un televisor Toshiba
Espero te sirva y puedas resolver el problema
Sino te sugiero busques un servico tecnico especializado
Saludos Franco Dosil
Toshiba... | Answered on May 16, 2019
If the current firmware in your blu-ray player supports multi region then try this.
1. Power on the blu-ray player.
2. Press "Setup" on the remote to enter Setup Menu.
3. Using the remote, enter "8520". A new submenu will appear.
4. Set DVD region code to "0" for DVD Multi Region.
5. Set BD region code as required using the remote buttons.
"1" = Region A, "2" = Region B, "4" = Region C
6. Press "Setup" button to exit the menu.
If this does not work then try upgrading the bluray firmware.
Search for Toshiba BDX2150 firmware and see if there is a newer firmware than the one you have installed.
Toshiba... | Answered on May 14, 2019
Toshiba MW30G71 30 in. TV/VCR/DVD Combo Logo
Popular Tags
19 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
toshiba tv dvd open
  • Televison & Video
