20 Most Recent Sony VPL-ES1 Multimedia Projector Questions & Answers
You MAY be in luck! There is NO mention of a 220VAC supply for your Sony Projector! However they DO specify a different AC Power Cable/Cord.
This means your Sony should work from 100VAC to 240VAC AS IS with the proper connector at the WALL end. NO other transformer should be required...
Download your Manual from the Link below and go to page 71.
Note that FIVE different cables are specified ~ depending on location...
I also suspect you can go to a local TV shop and buy the proper cable OR have them CUT the connector and install the correct type for your location.
Anthony
http://www.projectorcentral.com/pdf/projector_manual_3020.pdf
Sony VPL-ES1... | Answered on Dec 02, 2017
I think you may be having a problem with the projection bulb.
Sony VPL-ES1... | Answered on Jun 10, 2014
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
it is a little hard to test them. any help ,Pls contact me
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Sony VPL-ES1... | Answered on Mar 01, 2014
I have exactly teh same problem with mine.... I am in Springfield IL.
Have you figured the problem out yet?
Sony VPL-ES1... | Answered on Feb 16, 2014
I get this and similar questions often. You turn on your light. It makes noise, you can see lights - perhaps even blinking lights - and assume that it must be running.
wall light
Sony VPL-ES1... | Answered on Jun 08, 2012
ensure that the projector goes through the cool down cycle, for example the fans stop running, before you unplug it. Unplugging it will cause it to into power failure mode which will not allow the lamp to turn on until the bulb reaches ambient temperature. it will also extend the life of that very expensive bulb. take the extra time to let it shut down before you unplug it.
Sony VPL-ES1... | Answered on Jul 05, 2011
Yes there is, have a look at http://www.ambery.com/dvihdtovgadv.html
Sony VPL-ES1... | Answered on Mar 19, 2011
Yes, this projector will work on AC 110V supply.
Do you get any blinking light when projector refuse to turn On?
When did you replaced its lamp last time?
Let me know above info to diagnose possible cause of problem.
Thanks
Sony VPL-ES1... | Answered on Jan 22, 2011
check if standby led on projector is glowig red, if yes pannel keys may be in off mode, try to power on with remote control.if standby led does not glow, check power cable and its connections and safety fuse inside projector.
Sony VPL-ES1... | Answered on Aug 14, 2010
replace the lamp.
Sony VPL-ES1... | Answered on May 08, 2010
Hello :
These are the symptoms of overheating problem . You need to check the fans .
Are the input and output vents blocked or obstructed in any way?
Are the filters dirty or clogged? Most manufacturers will recommend filter cleaning on a monthly basis depending on usage
Remove any extension cords, power strips and/or surge suppressors. Many current model projectors will not even try to ignite the lamp if they detect drops or fluctuation in voltage supplied to the unit. This is a safety feature to reduce stress on the lamp.
PLEASE DON'T FORGET TO RATE !
Sony VPL-ES1... | Answered on Apr 12, 2010
Ok SCART is meant to be a "Standard" meaning all SCART should be the same, unfortunately they are NOT. Please have a look at the Wiki link below it will explain all. Some SCART plugs do not have all connection wired through, you must ensure your SCART cable has EVERY wire intact, we usually meter out our plugs to check, as we have been caught out too many times, usually the High end, ones are OK
http://en.wikipedia.org/wiki/SCART
Sony VPL-ES1... | Answered on Mar 19, 2010
usually the projector powers and cools down. if you restart it it will open the cover, not projecting anything and after 10 seconds it will close again. this happens if the lamp is shortly before the end of the measured lifetime (no fixed hours) to protect the projector. usually if you take it out once or twice it will work for 1 or 2 more times but the bulb is very likely to explode (not destroying the projector but not good anyways)
Sony VPL-ES1... | Answered on Aug 04, 2009
definately a lamp problem, for some reason the projector doesnt seem to accept or recognize the new lamp and switches to "safe mode". usually the projector turns off before the bulb explodes...
Sony VPL-ES1 Multimedia Projector Logo
33 questions posted
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
Paul
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Office Equipment & Supplies
Most Popular Question
sony
  • Office Equipment & Supplies
