FixYa.com
Sony VPL-CX70 Multimedia Projector
All Products > Sony > Multimedia Projectors
Problems with Sony VPL-CX70 Multimedia Projector?
Troubleshooting and Support
Solved Problems for Sony VPL-CX70 Multimedia Projector RSS Feed Post a New Problem
Movie projector vs data projector
Hi I'm pretty new to home-cinema, and have only been investigating options for about a week. I've narrowed...
7 Solutions
How do I redirect the output of my PC...
How do I redirect the output of my PC laptop to the projector?
1 Solution
my problem is that the Image is not...
my problem is that the Image is not stable, on my projector, any suggestions?
1 Solution
Projection Problem with Toshiba TLP 261
When the projector is turned on, it displays the default screen. In the lower left corner the display is red. Adjusting...
1 Solution
Epson EMP-82e locked out
One of our staff turned off the projectors power. He then proceeded to input the wrong security code and the projector...
1 Solution
Connecting Sky TV to my projector
I am finding it hard to connect my sky tv to my projector, which cable do i need.
2 Solutions
green tint
I just purchased an epson powerlight s1. All the highlights are green. I tried adjusting the color and tint, but nothing...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Sony VPL-CX70 Multimedia Projector RSS Feed Post a New Problem
sony data projector vpl-cx70
when turned on, the temp/fan and lamp/cover lights turn on (amber). power light turns amber then back to red. nothing...
Post a Solution
cover lens
the cover lensdon't open/close because the cover of little gear whose move the cover is break. Can I obtain this part ?
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC · Mac
TypeLCD Projector
Form FactorPortable
Display TechnologyTFT Active Matrix
Image Brightness2000 ANSI lumens
Contrast Ratio350:1
Max Resolution (Native)1024 x 768
Image Aspect Ratio4:3 (Standard) · 16:9 (Wide Screen)
Image Size (Diagonal)40 in. - 300 in.
Screen Distance80 ft. - 100 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1400 x 1050 (SXGA+)
Synchronization Range Horizontal19 - 92 kHz
Synchronization Range Vertical48 - 92 Hz
Technical Features
Audio OutputSpeaker(s)
Operation Noise30 dB
Interfaces
InterfaceUSB
Video Input15 Pin D-Sub VGA · 4 Pin - Mini DIN (S-Video) · Composite Video
Lamp
Lamp TypeUHP
Light Source Life2000 Hours
Light Source Power165W UHP
Other Features
Special FeaturesKeystone Correction
Speakers Output1 W
Projection MethodRear · Front · Ceiling
Standards
Analog Video FormatNTSC · PAL · PAL-M · PAL-N · SECAM · NTSC 4.43 · PAL 60
HDTV Formats720p · 1080i · 480p · 575p
Dimensions
Depth9.63 in.
Height2.75 in.
Width11.75 in.
Weight6.25 lb.
Sony Contact Information
Main support number800-488-7669
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
