FixYa.com
Sony VPL-CS7 Multimedia Projector
All Products > Sony > Multimedia Projectors
Problems with Sony VPL-CS7 Multimedia Projector?
Troubleshooting and Support
Solved Problems for Sony VPL-CS7 Multimedia Projector RSS Feed Post a New Problem
SET UP GONE ON NEXT USE
For no known reason the setup is now gone when we get ready to do another presentation. Now we have to go through the...
1 Solution
Lamp Cover will not close fully
The lamp cover is half open and half closed. I switch the projector on and the lamp indicator light flashes - the...
1 Solution
Projector- Sharp XR-20X won't start up
We have a fairly new projector- a Sharp multimedia projector, model xr-20x, that won't start up. We've gone through all...
1 Solution
Remote control for Canon LV X6 Projector
I cannot seem to get the remote control to work for the projector. I'm trying to use a PowerPoint Presentation and the...
1 Solution
user manual
hi i have this new beetel walk clip caller id cordless phone but i do not have the users manual,so i cannot load the...
1 Solution
InFoucus LP500 Projector
My InFocus LP500 projector has a pinkest image when connected to the Dell C840 laptop. I have update the display driver...
1 Solution
convergance problem on hitachi 51
asked at earlier date about convergance issue. very strange, sometimes we turn on set and within 30 seconds, picture is...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Sony VPL-CS7 Multimedia Projector RSS Feed Post a New Problem
image problem
Hello, I bought this projector second hand and it's fantastic, but.... it has got, what I can only describe as, a pale...
Post a Solution
VPL-CS7
the image is not good i see not clear from lcd panel
Post a Solution
Resolution Problem
My projector did not set in 800 x 600 2 picture seen in the screen kindly help me in this regards thanking your
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC · Mac
TypeLCD Projector
Form FactorPortable
Display TechnologyTFT Active Matrix
Image Brightness1800 ANSI lumens
Contrast Ratio350:1
Max Resolution (Native)800 x 600
Image Size (Diagonal)40 in. - 300 in.
Max Resolution (Interpolated)1024 x 768 (XGA)
Technical Features
Audio OutputSpeaker(s) · 3.5 mm Mini Jack
Operation Noise39 dB
Interfaces
InterfaceUSB
Video Input15 Pin D-Sub VGA · 4 Pin - Mini DIN (S-Video) · Composite Video
Lamp
Lamp TypeUHP
Light Source Life2000 Hours
Light Source Power185W UHP
Other Features
Special FeaturesKeystone Correction
Speakers Output1 W
Standards
Analog Video FormatNTSC · PAL · PAL-M · PAL-N · SECAM · NTSC 4.43
Warranty
Warranty2 Years
Dimensions
Depth9.38 in.
Height3.13 in.
Width11.63 in.
Weight6 lb.
Sony Contact Information
Main support number800-488-7669
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
