20 Most Recent Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95 Questions & Answers
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
Sony XL-2100U... | Answered on Aug 26, 2016
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Try this site too. Electrohelponline
Sony XL-2100U... | Answered on Nov 17, 2014
check the lamp first
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Sony XL-2100U... | Answered on Mar 24, 2014
just the bulb.. write down the model number of the unit and they will give you the same bulb that you need, just give them the model number.
If you are going to install the bulb just remember DO NOT HOLD directly the bulb, use any clothe or gloves, because even a fingerprint can busted the bulb even thou it's not yet use
Sony XL-2100U... | Answered on Oct 23, 2012
Lamp is burnt
Take lamp out and You will see problem, lamp made pop
Sony XL-2100U... | Answered on Aug 21, 2011
Hi there
Here is address and phone number to call for Your replacment lamp
Bleeker Stereo & Tv
1400 Clyde Ave Nepean
Ottawa On
K2G 3J2
613 225 5191
Give them call ..Cheers
The lcd panel may be faulty or one of the polarisers may have gone. May cost £300 to fix. May need to look at a new projector.
Hope I was of assistance
Sony XL-2100U... | Answered on Aug 05, 2011
This page shows Sony lamp location and bulb replacement.
Sony DIY Bulb Guide.
The XL2100 Lamp assembly is located behind the grill, under the front screen. Thumbscrews on left and right loosen and the panel pulls off.
Open Lamp access door by loosening the thumbscrew on the front. The lamp is behind the door and attached by two mounting screws. The mounting screws require an "Allen" or Hex key.
Never attempt to access the bulb or open the door when the bulb is hot. Allow 30 minutes to cool.
Look for specific LED indicator codes on the front of the TV. An explanation of the most likely fault is in your Sony user's manual. Links to free Sony user manuals are also on the link above. Lots of instructions regarding safety, mercury disposal, removing the lamp.
Do not buy a bulb and waste your money if any Sony TV Optical Block or Optical Engine Faults are or were visible before bulb failure.
easyab
Sony XL-2100U... | Answered on Feb 24, 2011
hi,
here's a video guide http://www.youtube.com/watch?v=GQGTy-KVN8Y fo this model which will hoefully help...
Sony XL-2100U... | Answered on Feb 22, 2011
yes you are correct.As per the led light blinks.Five blink is for lamp replacement.And seven blink is for audio problem. Lamp replacement is just removing the old lamp and fitting new lamp and resetting the lamp timer.But audio problem is replacing the internal electrical components.In this you have to do bit of troubleshooting.You have to check few parts with meter to confirm the fault. --------- There are few circuit boards in the sony kf-60we610 unit.In that you have to check IC8504(A board), IC4704(AU board), PS1601 or 1602 (G1 board).If this Ic checked out faulty then it has to be replaced.You can get replacement Ic from online www.radioshack.com site. ---------- If you are not familiar with testing this parts,then it has to be done by local tv repair tech.First the ic parts are to be checked,then faulty one has to be Replaced.in some cases the D_board itself has to be replaced.But in most of the cases replacing the 2 ic helps to solve the problem. ---------------------- This should help.Thanks.Helpmech.
Sony XL-2100U... | Answered on Jan 22, 2011
Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95 Logo
114 questions posted
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
jasbo
jasbo
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Office Equipment & Supplies
Most Popular Question
access
  • Office Equipment & Supplies
