20 Most Recent Sony Mic n Micro M-100MC Handheld Cassette Voice Recorder Questions & Answers
It was given to me without manual so i don't know how to use it
You may get the manual here.
1/27/2012 11:24:59 PM • Sony Mic n Micro... • Answered on Jan 27, 2012
The recording playback is very weak and barely
Hello check your microcassette settings is probably set on 1.2 Speed and regarding about software. there is and option but I don't recomend that option becouse you canget another recorder with software included and better quality I recomend this unit. http://www.tvps.com/Products/Olympus-DS-40-Digital-Portable-Voice-Recorder---Factory-Refurbished__OL-P-DS-40.aspx
2/16/2010 12:44:13 AM • Sony Mic n Micro... • Answered on Feb 16, 2010
How do I preset a second AM station on a Sony SRF-M97 Walkman
It looks like the manual knows, and you can have 5 AM station presets and 15 FM. https://www.google.com/search?q=preset+a+second+AM+station+on+a+Sony+SRF-M97+Walkman ..
4/18/2024 5:09:49 AM • Sony Audio... • Answered Yesterday
Sony PS-FL7 direct drive turntable. When start button is pressed it illuminates but turntable won't rotate. All other functions work as they should.
'Direct Drive' appears to mean something different to Sony unless the belt is for another function. https://lptunes.com/products/sony-ps-fl7-ii-ps-fl7-ii-psfl7-ii-turntable-tonearm-belt-replacement Service Manual
Sony PS-FL7 Stereo Turntable System Manual
Vinyl Engine https://www.vinylengine.com > library > sony > ps-fl7 Sony PS-FL7 owners manual, service manuals and schematics are for reference only and the Vinyl Engine bears no responsibility for errors or other inaccuracies. "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(56px);"> Rating: 8/10 · ‎ 4 reviews
SONY PS-FL7 service manuals download
NoDevice https://www.nodevice.com > ... > Vinyl Players > SONY SONY PS-FL7 service manual (Vinyl Players) in PDF format will help to repair SONY PS-FL7, find errors and restore the device's functionality. ..
4/6/2024 7:54:41 PM • Sony Audio... • Answered on Apr 06, 2024
My sony icf-cl75ip wont turn on and is making a clicking sound. How can I fix this?
There is not reason this would click and not turn on. If it just clicked, it would likely be caused by interference from another appliance, typically a fridge or freezer. The most likely reason is a relay in the internal power supply. It will need a Sony Service Centre. https://www.sony.com/electronics/support/res/manuals/4154/41545841M.pdf It isn't a recorded known issue. Sony are high quality equipment so it is worth getting it fixed. https://www.google.com/search?q=sony+icf-cl75ip+clicks+and+not+working ..
4/6/2024 2:59:06 AM • Sony Audio... • Answered on Apr 06, 2024
Hello Sir. My Sony Deck MHC RV-900D Stereo, it's front panel is not working. I changed the fuse, replaced it but after no response. Please Help me Sir, Thanks.
Open it up and look for bulging or split electrolytic capacitors, especially in the back to the display and the power supply. Or take to an electronics technician for diagnosis. https://www.google.com/search?q=Sony+deck+MHC+RV900D+not+working ..
4/3/2024 2:34:25 AM • Sony Audio... • Answered on Apr 03, 2024
Sony Music system error code display c81, what is minig
C81 error indicates an internal hardware fault.Check CD mechanism is not jammed.
3/3/2024 7:36:52 AM • Sony Audio... • Answered on Mar 03, 2024
Sony Audio Rack SU-S5520. Need a power cord for it please?
Question edited for clarity, turned around plus CAPS. It should be a standard figure 8 connector. https://www.google.com/search?q=sony+audio+rack+su-s5520+power+cord+replacement ..
3/1/2024 8:31:36 PM • Sony Audio... • Answered on Mar 01, 2024
I need code for Sony MHC VX33 sound IC
STK402, IC501. Part number 8-749-016-96
2/23/2024 6:13:11 PM • Sony Audio... • Answered on Feb 23, 2024
Sony mhc-gnz888d is on standby and wont power on
Standby problem solved
2/19/2024 4:08:20 PM • Sony Audio... • Answered on Feb 19, 2024
Why is my Sony DZ- 840K Home Theater displaying "Please Wait" like for ever, without loading to play anything. Please I need an urgent remedy to this problem.
You realize we are Fixya dot com and we aren't Sony Support? We don't do 'urgent remedies' although we do try to help for free. https://www.google.com/search?q=Sony+DZ-+840K+Home+Theater+displaying+%22Please+Wait%22 I wrote this Fixya Tip which you can try first. https://www.fixya.com/support/r29927004-dvd_player_or_cd_player_not_reading ..
2/9/2024 5:57:26 AM • Sony Audio... • Answered on Feb 09, 2024
I have a Sony stereo system PS-LX47P. The turntable has stopped working, I have changed the belt,but still not working. Can any Sony turntable be used to replace it?
The record deck is known as a PS-LK47P. If you wish, another deck will work as long as it has a magnetic cartridge and no preamp built in. A Technics SL-1200 is the sort that is fine and a definate upgrade.
1/30/2024 7:38:29 PM • Sony Audio... • Answered on Jan 30, 2024
My Sony MHC rv22 blinking red light and its not getting on
This problem is discussed in troubleshooting section on page 37 of manual MHC-RV555/RV55/RV222/RV22 (sony.com)
1/16/2024 12:00:26 PM • Sony Audio... • Answered on Jan 16, 2024
2answers
I have a Sony STR-AV770 receiver that has stopped
your question depends on how good you are at electronic diagnosis (symptom diagnosis) and how adept you are at removing and installing electronc components. first you have to determine why the amplifier has stopped working on the left channel. Make sure that the problem isn't a simple one, take the speakers off the right side and hook them to the left side and see if you get sound. If you do,, then the problem is the left speaker or left speaker wire. If you don't get sound then tyr taking the input that feeds the right channel and pluggin it into the left channel and listen for sound, if you get sound now the problem was the signal from your source not being sent down the left side.
If it still doesn't work you need to move inside the amplfier, but first, get close to the back of the amp and give a sniff, do you smell anything (a pungent burnt wire or rubber smell) if you do, the the chances are good that some components have burned out. Do you recall having a shorted speaker wire on the left side? shorted speaker wires are notorious (especailly older equipment) for burning out the final amplifer stage. If this was an expensive amp it might be worth fixing, if its not worth much then maybe you should consider religating it to use as a monophonic amplifier (one channel) you could use it to power a sub woofer in a hibryd stereo or surround sound system.
I don't know what more I can tell you at this point. If you go through the steps I outlined, and want to tell me the result I shall be glad to respond and maybe give you another direction to head in. good luck and I'm glad you are adventruous enough to want to try.
1/1/2024 6:17:24 PM • Sony Audio... • Answered on Jan 01, 2024
Sony MDS-JE520 - Minidisc player. Does it play discs recorded in long play please?
Question edited for clarity.
Can a Sony MDS-JE520 play 80-minute MD's (and also ...
Reddit · r/minidisc 5 comments · 1 year ago The JE520 will not play anything recorded in MDLP, or any discs that have been converted to HiMD mode. MDLP (LP2, LP4) tracks will show up ... 4 answers · Top answer: Hello, The MDS-JE520 should have no trouble recording and playing 80-minute MDs in SP ... First I've seen around here! Sony MDS-JE520 deck. Couldn't ... Feb 24, 2023 Home Decks that can play MDLP : r/minidisc - Reddit Jan 1, 2022 Sony MDS-JE510 Not Recording : r/minidisc - Reddit Feb 20, 2022 My Sony MDS-JE500 is scratching my minidiscs while ... - Reddit Mar 10, 2023 More results from www.reddit.com Specs, Manual and Service Manual https://www.minidisc.wiki/equipment/sony/deck/mds-je520 ..
12/12/2023 5:23:00 AM • Sony Audio... • Answered on Dec 12, 2023
Sony Mic n Micro M-100MC Handheld Cassette Voice Recorder Logo
5 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
given me without manual dont know use
  • Audio Players & Recorders
