FixYa.com
Paradyne 6381 ADSL2+/ReachDSL Router
All Products > Paradyne > Routers
Problems with Paradyne 6381 ADSL2+/ReachDSL Router?
Troubleshooting and Support
Solved Problems for Paradyne 6381 ADSL2+/ReachDSL Router RSS Feed Post a New Problem
6381-A3-302,6211-I1-300 Paradyne ADSL...
I have 6381-A3-302 router when it is switched on then ping shows request time out while LAN status light remains solid...
5 Solutions
No status light
Hi, I have a paradyne wireless router model 6388-A1-200 and its been working fine until 2 days ago the status light just...
1 Solution
x box 360
hi my dsl with computer works fine but i unplug network cord and plug in new cord and try to get connected with x box...
1 Solution
trying to set up pptp on a Paradyne 6381
Everytime we try an connect we get error 800, cannot reach server. We have opened vpn for each pc on the lan, and we are...
2 Solutions
IP ADDRESS TO OPEN ROUTER
6381-A3-200 HOW TO GET THE IP ADDRESS TO ROUTER
1 Solution
help plz!
I NEED TO SET MY MODEM TO BRIDGE MODE CA U HELP?
2 Solutions
Network between two remote location within...
I am having one office at one location (LAN network address is 10.10.10.0 / 255.255.255.0). Other office (LAN network...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Paradyne 6381 ADSL2+/ReachDSL Router RSS Feed Post a New Problem
Using both USB and Ethernet to connect to...
hello, i have 2 pcs that i use to connect to the internet, i currently use a paradyne 6381-a3 router/modem to connect to...
Post a Solution
Using both USB and Ethernet port to...
Post a Solution
port fowarding
i have tried everything..even dmz and my ports arent open still...i am not so sure if all my firewallls are down..is...
Post a Solution
PARADYNE 6381 DSL MODEM
I have a paradyne 6381 dsl modem directly connected with my Cisco 24-ports switch have a specific IP address. when i...
Post a Solution
No activity light
hi i have a paradyne 6381-a3 the activity light is not on and i am downloading and my dl are slow Can u tell me what the...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
ConnectivityWired
FunctionalitiesFirewall, DHCP Server
Interfaces
Built-In1-port Built-In Switch
LAN Interfaces10/100 Base-T
Additional Interfaces1 x USB
Standards and Protocols
Management ProtocolSNMP, Web Based / HTTP, Telnet, TFTP
StandardsIEEE 802.3 Ethernet, IEEE 802.3u Fast Ethernet, DSL, ADSL, G.Lite
Routing ProtocolsRIP Version 1, RIP Version 2, Static Routing
ProtocolsARP, ATM, DHCP, ICMP, IP, PPP, PPPoA, PPPoE, TCP, UDP, G.Handshake
Other Features
Additional FeaturesUPnP Certified
Dimensions
Depth4.4 in.
Height1.2 in.
Width6 in.
Weight1.5 lb.
Paradyne Contact Information
Main support number1-800-795-8004
Support FAX727-532-5805
Email supportsupport@paradyne.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
