out aiwa xd-dv370 seems to be "locking up" it takes forever to get it to open or to play a...
(More)
out aiwa xd-dv370 seems to be "locking up" it takes forever to get it to open or to play a disc. we unhooked it from power about a month ago and just hooked it back up
trying to play a dvd movie in my Aiwa dvd player. Has been working fine but now every dvd i put it...
(More)
trying to play a dvd movie in my Aiwa dvd player. Has been working fine but now every dvd i put it it - it reads "disc error" and won't play any movies. How can I fix this?
I turned it on one day and put a dvd in. Then all of a sudden the tv went black and the player was...
(More)
I turned it on one day and put a dvd in. Then all of a sudden the tv went black and the player was unresponsive. I unplugged it and plugged it back in and when I turned it on the program indicator (PROG.) was on with two hyphens (--) underneath it, I was unable to open the tray to retrieve my dvd, and the unit was just unresponsive in general.
Will play back CD's,Newspaper film DVD's, Promotional DVD,s.But refuses to play back a DVD-RW that...
(More)
Will play back CD's,Newspaper film DVD's, Promotional DVD,s.But refuses to play back a DVD-RW that is recorded on my Toshiba!!! HELP !! Colin.
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
