20 Most Recent
Aiwa CDC-X115 Questions & Answers
AIWA CDC-X115
Check BOTH of your power connections and your ground too. Make sure you actually have 12v at each connection and don't have a blown fuse etc. If you are lucky then you will solve the problem. Good luck.
Aiwa cdc-x204
try disconnecting the battery to see if that will reset the device. Let me know what the outcome is and we will go from there to fix this. Just make sure to respond here in a timely matter so that we can get you on your way as soon as possible.
good luck
Fuse for the ash tray for the crysler 300
Fuse #9 feeds the power outlet and fuse #18 feeds the lighter outlet (this is the one I believe your having trouble with).
They are both located in the fuse box in the trunk, next to the battery. If you open the trunk and lift the floor up you'll see them hiding under there. The numbers should be called out on the cover for the fuse box.
Install instructions pyle pld33mu into chevy impala
I'm
sorry but I believe you have this posted in the wrong product
category? Please re-post the question in the proper category if this
is the case, otherwise you have my apologies. This is the car and
truck problem category
Ur ***
Please describe the problem .
Regards
What is the best way to retrieve a CD from the
Get two nail files, cover the ends of them with scotch tape, and insert them one at a time so that one goes over the disc, and the other goes under... Press them together firmly and pull slowly while wiggling left and right gently.
This may work, but may not - most CD players have a lock in them, and the disc platter goes up to lock the disc in place as well, so that it can't move while spinning. Depends on the disc's position in the player, really.
