Troubleshooting & Support
Hot Topics:
- wiring
- demo
- replace...
- aiwa cdc x504mp
- cdc demo mode...
- x504mp
- set clock
- faceplate
- installing cd...
- wiring diagram
- demo mode turn
- Buttons don...
- radio working
- cdc x504mp not...
- wire harness
- cdc x504mp
- aiwa cdc x504mp...
- controls
- cd skips
- unlock code
- CD not eject
- ribbon cables
- car
- display
- aiwa cdc r30mp
- cdc 504mp
- reset
- demo mode
- eject CD
- security code
- View All »
Problems & Solutions
Aiwa CDC-X504Mp stuck in demo mode
i had the same problem. and after many attempts i found the way to unlock demo mode. put your player into setting mode of the clock by...
stuck in demo
I had the same issue and was about to give up. cleaning, key combos and such didn't work out. Solved the dirty way, as described some...
I have a CDC-X504MP. How
To get to the sound settings: Press and hold the Volume knob down. Press the "Seek" button until you see "Fad" on the...
Need manual to set clock,etc
To set the clock: Press and hold the "Disp" button until the clock shows in the display window. Turn the Volume knob to turn the...
I pulled this Aiwa stereo
You can get the install manual on the link below page 24. http://a248.e.akamai.net/pix.crutchfield.com/Manuals/055/055CDCX504.PDF
cant insert a cd into the unit
this is due to insert area with other problems
what is the amplifier used on it
The amplifier is the system that controls the audio.
cd will not eject
you can try disconnecting power to the stereo for a few minutes. sometimes the reset switch doesn't always completely clear the memory...
I have a CDC X504MP in my honda civc and I cannot
I have the same problem in my civic, is it a brand new deck, or did it just stop working?
all power and grounds work cd player si not coming
on the amp try gettin a different wire connecting the power stright to the remote useing a different wire touch both of them . and see if...
'97 buick lesabre's security alarm has...
I had a related problem with a new car. It turned out to be the battery shorting out internally. For some reason it always happened at...
Car horn and lights sound alarm @ random times...
Alarm DisarmLIGHT GREEN(-)DRIVER'S KICK PANEL
I have a Aiwa CT-FX929m Car radio in my car. It
This should help you in your installation.
when i try to play a cd it tells me to reset the...
is your cd player aftermarket or oem if oem look in owners manuel u will have to do a soft reset on the radio if not disconect positive...
WHEN I PUT THE POSTIVE BATTERY CABLE ON
I'm guessing that you mean the car battery, this is normal on most cars
Unsolved Problems
no puedo insertar un CD
no puedo insertar un CD al equipo AIWA CDC-X504MP y siempre sale en la pantalla CD RESET, que hago?
o meu cd play aotomotivo
o meu cd play aotomotivo esta dificil de ligar e quando liga só funciona o controle, no aparelho não...
why when the stereo i
why when the stereo i hooked up correctly it doesnt work
I have a CDC-X504MP player
I have a CDC-X504MP player but the CD stop working. When I try to insert cd the player wont take it. How can I fix the...
It is on and everything and just keep going
It is on and everything and just keep going through all of the things on the screen and I cant get it to the tuner to...
while driving and listening to
while driving and listening to my radio model #cdc-x504mp, it suddenly cut out. the faceplate illuminates, and proceeds...
Out of the blue, EVERY button on the console does
Out of the blue, EVERY button on the console does not respond! The unit has power but will not enter "play" mode for cd,...
my Aiwa CDC-X504MP somehow lockup and only button
My Aiwa CDC-X504MP somehow lockup and only button that is work is display button when i press it for few second and than...
Upload a manual for Aiwa CDC-X504MP CD Player
Specifications
TopKey Features
Full Product Name:Aiwa CDC-X504MP CD Player
Player Type:CD
MP3 / WMA Playback:MP3 Playback
Anti-Theft Protection:Detachable Face Panel
Amplifier / Speakers
Built-In Power Amplifier:Yes
Built-In Amplifier Power:4 x 52 Watt
Built-In Amplifier RMS Power:4 x 23 Watts RMS
Radio
Tuner Type:FM / AM
FM Presets:18
AM Presets:12
Dimensions
Depth:6.13 in.
Height:2 in.
Width:7.2 in.
Warranty
Warranty:1 Year
What's your problem?
Fix-O-Meter
6,851
6,851 people have viewed this product
- 31 people asked about this product.
- 12 people found solutions for this product.
- 2 people have added this product.
How to Enter a...
How to reset...
Basic wiring...
